Lear 25D: Pros and cons please
With the cookie cutter diffusers on the back of the 610's people will honestly laugh and point... There are so few of them out there... and in addition to that you lose the use of the TR's and combine that with high ref speeds and little tiny wheels and brakes.... it gets even more fun to try and stop.
It will climb all the way to FL410 at .78 and still be at max gross weight once it reaches FL410 assuming that you miscalculated your take off weight... ;-)
LB
LB
I have flown the 20's with and without TRs. The loose of TRs is not a big deal. Using aerodynamic braking and a light touch on the brakes, you can get more life out of the brakes then most of the guys who use the TRs. On the Dee Howard TRs, the engines tend to spool up before the clamshells are fully closed. Without the TRs the aircraft is quite a bit lighter and you get a touch more performance out of the aircraft.
As for the high ref speeds, that only applies to the original wing. And I can't remember the last time I saw one. On the Mark II wing, the FAA put out a bulletin to add additional speed to the landing speeds. Mostly because the FAA was scared to death of the aircraft.
Personally I like to fly any Lear with Winglets vs. one with Tanks....
The Sabre 65 will be tough on mx too. Parts are, of course, out of production. However, very nice flying airplane in all facets of flight. We used to get our mx done in perryville, mo. No problem with de-ice. Kind of a hog on hot days, but what isn't. The 25D is also a great airplane. My first jet, so I am biased towards it. So much fun to fly. But I swear I got about 4 inches shorter over the time I flew it. Very small cockpit.
...Seems like all of the Lear 25D's around have 'XA' Tail numbers...
Westwind is more airplane and does more than the Lear, but operating cost will be the consideration.
CJ-610's are bullet proof, as most of the 20 series Lears are as well. But if parts are getting to be a concern for 20 series, then maybe a 30 series or Westwind will be a better choice. 35's are for grandpas though, just sayin, but then this isnt the 90's anymore either.
Sabreliner Corporation, at the old factory in Missouri, still makes all parts for all Sabreliners. They will guarantee any part for any Sabre within 14 days. Much better support than many "still in production" aircraft.
Cessna wants the old Citations to go away. Lear is the same way with 20 & 30 series. Sabreliner Corp., because of the many military Sabre's flying, is in business to support their out of production aircraft.
Get a Falcon 10. Bigger cabin, faster, more range, easier to fly and live with.
FWIW...
A big +1 on BOTH the Sabre 65 and the Falcon 10. You WILL NOT find better product support for an out of production aircraft than Sabreliner. They are top notch. In a previous life, i worked for a company that had both a Falcon 10 and a 65 on their 135 cert. Both are excellent airplanes, with the 65 being a little better. It has GREAT range for a biz jet.
Just be sure to get a Falcon 10 with the single point fueling mod...
Man....you're gonna make me sentimental for my old Westwind!! :D We had some fun!!
For my 2 cents worth I would not consider any CJ-610 powered aircraft. Sorry, but that is just the way I see it.
As for your options, they are:
Westwind, preferably a Westwind II. Yeah, I know, it's ugly and not all that fast, but it does have an excellent range for that class of business jet. Also from what I understand there is still good parts support.
Saber 65, this would be my choice. As someone else mentioned, it still has great parts support. It is fast, same range as the Westwind II, but much nicer to fly and a lot better looking.
I have about a 1,000 hours in both the Westwind II and the Saber 65. However, in regard to the Falcon 10/100 I only have one takeoff and one landing on a demo flight, so I cannot address the Falcon, except it is an excellent flying aircraft, as all Falcons are.
Last time I checked the Saber 65 is a little more expensive to buy than the Westwind II, but as far as I am concerned the little extra for the 65 is worth it.
Anyway, good luck and have fun finding the right aircraft.
Westwinds I/II are a lot of bang for the buck....but again another airplane WAY past its useful, reliable life IMO.
I flew them about 10yrs ago and they were mx intensive and nose-diving in value.
Theres a reason these planes change hands so quickly. The estimated costs may sit OK with the new owner, until his 30+yr old pile of crap gets into an inspection or breaks 3X in a month.
Quite often with these things, someone really wants their own jet - but simply cant afford it.
And comparing looks between a Westwind and a Sabre?.....yikes thats like a fat, smelly, ugly chik contest. Throw the Astra and the Raytheon Premier in there and its as bad as it can get.
...If he wants a Lear 25 why not look into VLJ's? They are about the same price(ish) and they will operate for nothing in comparison to an old airplane, probably will be more comfortable with more baggage if you dont need to squeeze more than 5 people on board.
I hate to say this, but you are quite correct about the Westwind II. I guess the reason I mentioned the Westwind/II is because there are a lot of them around here, there is a major maintenance facility for Westwinds here.
Sadly the same could be said about the 65, but as previously pointed out, the Saberliner support is exceptional and I still feel you get a lot more out of your money for 65 when compared to either of the Westwind aircraft. Last time I checked all Saber 65s are RVSM capable, I don't think you could say that for the Westwinds.
We replaced our 65 with a Falcon 50EX. The Sabre was on the market for quite some time and it finally sold in Mexico.
However, please remember this, just a few months ago a Sabre 65 set a new speed record for flying around the world for its type and class of aircraft. That ain't too bad for a 30 year old biz-jet.
It might sound simple but the baggage capacity SUCKS! You have to load bags through the cabin (which was a lot of fun in 115 degree Arizona heat). and once the crew baggage is in there is room for about 2-3 small bags.
I think there's plenty of room in there if you know how to load it. Being an ex freight dog has its advantages when figuring out how many bags you can stuff back there..
I never flew the 65, but the Sabreliner is a fantastic airplane. I don't think there is a better flying jet out there (the 40 was a piece of cake to hand fly at FL410 with the yaw damper off - try that in a Lear).
The worst system on the 40/60 was probably the anti-skid, rather primitive by today's standards.
We had great luck with support from AVMATS at SUS - don't know if they are still supporting the Sabres or not (I crossed over to the 121 dark side 10+ years ago).
IIRC, at least on paper, the Westwind and the 65 were fairly comparable. That said, the Westwind was a real pig in the handling department compared to the Sabre.
Just my thoughts...
The worst system on the 40/60 was the nosewheel steering. From a maintenance perspective, having worked on them, it's overly complicated, prone to failure, and a pain in the butt.
The worst part of the Sabreliner line is the structure. If most pilots flying them, or who have flown them, had any idea of how much corrosion exists in every one of them, they'd shudder and run away.
It's intergranular, and it's in the skin; it's found everywhere, and has nothing to do with corrosion prevention: it's inherent to the material and building techniques of the aircraft.
The Sabre is a nice flying airplane...but so is the Learjet. The Lear isn't that much of a challenge to fly at altitude with autopilot and yaw damper off...even with full tips in a 20 series.
Avmats still does.
The Lear 31a and 45 can be hand flown with no yaw damp (not required) all the way up to FL510 and I have done that with no problems. Which Saberliner can do that? ....LOL
