You too can fly the worlds fastest jets. Glasses OK!
1-800-FLY-NAVY
Don't believe everything you read.
Here are the jetBlue First Officer criteria:
II. Minimum Qualifications:
• 1500 hours total time in airplanes (excluded: Helicopter, Simulator, Flight Engineer time)
• 1000 hours turbine in airplanes
• 1000 hours Pilot in Command Time*
• 1000 hours in airplanes at or above 20,000 pounds (maximum takeoff weight) or 1000 hours in large turbojet airplanes (12,500 lbs or above)
• Recency of flight experience will be considered
• Federal Aviation Administration (FAA) Airline Transport Pilot (ATP) Certification
• Current FAA Class 1 Medical Certificate
• Federal Communication Commission (FCC) Radio License
• Valid Passport with the ability to travel in and out of the United States
• Three reference letters from Pilots who can personally attest to the candidate’s flying skills (must bring originals to interview)
• Vision corrected to 20/20
• High School Diploma or General Education Development (GED) Diploma required , College Degree preferred but not required
• Regular attendance is required
• Must be an appropriate organizational fit for the JetBlue culture, that is, exhibit the JetBlue values of Safety, Caring, Integrity, Fun and Passion
• Must be well groomed and maintain a professional appearance
• Must pass a ten (10) year background check and pre-employment drug test
• Must be legally eligible to work in the country in which the position is located
*JetBlue will only consider PIC time when the Pilot has signed for the aircraft. Please use only this time when completing the areas of the application asking for PIC time to be entered.
Candidates who have previously interviewed will be ineligible for another opportunity to do so for a period of six (6) months from the date of their last interview
Competitive Qualifications
Our computers surface the most competitive applicants in the database. These files are then reviewed by a team of line Pilots. Due to the high volume of applications we receive, competitive qualifications can be significantly higher than the minimum requirements. On average, we are currently seeing the following background in candidates selected to interview:
• Between 3,000 and 10,000 hours total time in airplanes
• Greater than 2,000 hours turbine PIC in jets
• Greater than 2,000 hours in airplanes at or above 20,000 pounds (maximum takeoff weight)
• Experience with more sophisticated aircraft utilizing Electronic Flight Instrument Systems (EFIS), Flight Management Systems (FMS)
• Bachelor’s Degree
32LT10 said:I have seen many ads touting the route from FSI directly to JBLU. Are you saying these guys and gals are highly experienced?
1-800-FLY-NAVY
• Bachelor’s Degree
