Interesting MOA encounter with Viper
:rolleyes: Oh boy, with that attitude, you'll live up to your username pretty quick.
TCAS was never designed to deal with the dynamics and closure rates created by some tool wandering into a BFM engagement. Transiting that MOA was absolutely irresponsible, TCAS or not.
You have no idea what's really going on in that MOA. One of those fighter pilots may spend the better part of a minute flying his aircraft at 250-500 knots with vertical speeds up to 20,000+ fpm while looking backward - with just an occasional glance forward for info like altitude or airspeed.
Meanwhile, this idiot is trying to get out of the way using 1000 fpm while listening to "climb, climb now - no... wait - descend, increase descent - uuuhhh - ?monitor vertical speed? - you're gonna die!!!!"
You're absolutely kidding yourself if you think TCAS would make any difference at all. Not to mention, the proximity of these fighters was most likely well outside the ranges these idiots claim.
?Yankin and bankin? Keep in mind, TCAS only relies on vertical speed changes to attempt to avoid conflict - not lateral changes. So, there should be no "bankin" as you flail around trying to get out of the way. Do yourself a favor and don't transit an active MOA thinking TCAS is going to keep you safe.
The 'bankin' would be rolling to the 90 to get going down hill fast.
I'm gonna ask this again because this happened around the same time as the TFR for the F16 crash in the GladBag MOA.
Does anyone know if one or both of these guys got close to or violated said TFR?
I understand an respect all of your responses.
I still think the constant pursuit and the form up was a bad idea in this situation...especially on two separate aircraft.
That's because you don't know any better. Like Russian said, ATC won't let you tranist IFR, why the hell would you do it VFR? They don't let you do it IFR because they can't assure safe separation. When I go from 18K' to 5K', at speeds between 500 knots and 90 knots, tangled up with three other jets in the middle of a furball, we are not (nor do we have the capacity) to look for your dumb a@@ trundling through "because it's legal." It's legal to plow through a thunderstorm. Go do that too and get back too me.
ATC won't let you transition IFR because they don't want the extra work load of separating.
My exception to your position is this wasn't a high closure rate situation...and nobody was 'tangled up'. This was a gradual merge that the civies TCAS COULD pick up and did...creating the situation.
I'm getting the feeling you guys didn't know chasing civies set their TCAS off?
Anyway this is obviously a problem and the old forming up to get tail#'s in an MOA is probably gonna create more problems...why do you get tail#'s in an MOA anyway? Civies are in there legally.
What I don't understand is why the military folks don't get a bona-fide Restricted area to practice in.
makes absolutely no sense.
Where to start on this one...
First, there was a high likelihood of a high closure situation. If someone is going to get joined on, it's because the "fight" (the tangled up portion) was already knocked off because someone picked up a civilian in the MOA on radar. It's a training rule...if an unbriefed flight enters the airspace you knock it off until you can find the guy. The dangerous situation was avoided when the fighters stopped tactical maneuvering prior to the rejoin.
The dangerous situation was created when our civilian friend entered a hot MOA.
Second, we do know that M3C sets off a TCAS. Many of us are airline pilots, remember? As stated earlier, there is a strong possibility that not all fighters in the MOA are squawking M3. You do realize that fighters can squawk other modes and do so on a regular basis?
Finally, WE CAN'T GET MORE BONA FIDE RESTRICTED AREAS BECAUSE ALL THE DAMN GA PILOTS AND THE FAA BITCH LIKE MAD WHEN WE ASK FOR MORE AIRSPACE!!
Clear enough on that final point?
Sorry for the all caps, but if you understood the dogfight (pun intended) that it takes to just KEEP the restricted areas and ranges we haven't lost already, you'd see where I was coming from.
The idea of actually getting MORE airspace is a nice thought, but it ends there.
How in the world did this thread get twisted into whether or not the civvies should've been in the MOA? Everyone agrees they should not have been. I just didn't realize that so many people would think the appropriate response from the mil side would be to join up on those particular aircraft. I've been in alot of MOAs myself, even had to KIO a few times for unbriefed aircraft in the area. I never once considered joining up on them as some kind of way to "flip 'em the bird" or show them what dumba**es they were. Mostly because I'm not a dumba** myself. However, I will caution anyone out there who thinks that joining up on civilian aircraft is a good idea, especially without orders to do so, that nothing good can come of it. It's your career, your wings. Have at it if you think you're justified in doing so. Just realize that only support you'll get is from the posters here at FI.com.
Now why would you do that. I believe the initial response time required by any TCAS RA is 3 seconds using "normal control inputs".
Perhaps that is the special "holy sh--, I sure wish I didn't decide to transit this active MOA relying on my TCAS" response?
I have no dog in this fight but here are a couple thoughts:
With jetfuel at $4-$7/gallon these days, the mil guys better get used to this kind of thing.
The difference in the civilian world these days between flying a trip IFR vs. VFR can be several thousand dollars in fuel costs alone.
In this case if the flights in question were receiving flight following, why didn't the controller say anything? I realize that radar advisories are on a time and workload permitting basis, but two targets that appear to be merging above 10,000 ft., whether IFR or VFR, should get the controller's attention, especially when someone on the freq yells out that he's responding to an RA.
Lastly I would agree that flying through a known active MOA is not smart if you value your life, but sometimes the VFR guy is in there for a reason. Perfect example, I used to fly a crop survey for the government that in one area required me to be inside an MOA. What choice did I have? The same government that is paying to train its DOD pilots in that airspace is paying other pilots to survey the ground beneath that airspace. I couldn't wait till the MOA was cold, I had to go in when the weather was right, during the daylight hours and when I was told to do so. I would define that as being between a rock and a hard place.
Again I totally agree that there needs to be more airspace set aside for training, MOAs are a political compromise. Unfortunately the one thing they compromise the most is the safety of the aircraft that they were designed to serve in the first place.
Alright, I can't take it anymore...
1. Military fighter pilots are not going to "get used to" looking for civilian clowns in the middle of a hot MOA that are doing 200 knots while we're trying to lead a 4 ship of fighters doing 500 knots plus, whether gas is $4, $10, or $100 a gallon. When the MOA is hot, it's hot. There is a reason why we're there, i.e. we're in there training to ensure we keep this country free. I don't give a flying f*ck what gas costs you, but I'm sure you'd rather have us in there training than you speaking Chinese and having zero ability to buy gas freely at all.
2. You don't have a dog in this fight, you did get that part correct. You don't know the first thing about what we do, and in this case ignorance is not bliss.
3. And frankly you're right about it's not smart flying through a MOA if you do indeed value you're life. Reference bullet #1. I'm sure paying a little more in gas costs certainly outweighs you never flying again right?
Bottom line for all civilian guys out there - don't fly through a hot MOA (legal or not). It's just plain stupid. I grew up flying 172's long before I joined the military so I have all the respect for GA. And I also fly for the airlines. But don't be an idiot.
I've almost had a midair with GA in twice in Gladden. Both times in the middle of a BFM set, while I was defensive teaching a stud offense.
Most GA guys are surprised to know those areas are uncontrolled, we get no warning from anyone that a civilian in entering the airspace, and we DO NOT have TCAS. No warning+no control+no TCAS=No SA. If we find someone during BFM it's pure luck, and hopefully we don't trade paint.
I agree it was poor judgement to rejoin on the idiots. I did find the appropriate time to demo flare jettison to my student after missing a Bonanza by 500', though. The Bo made for the border pretty quickly...
Don't know if US F-16s are allowed to do this, but in our Air Force we always select mode C off before intercepting Civilian aircraft in order not to set of a TCAS resolution advisory. Our GCI Controller has to know that we are doing it.
Also, the civilian will if he is in contact with any agency get notifed that we are doing it. If he has legal right to be there I wouldn't go within 1000' unless he lets me.
We do however sometimes set of TCAS on aircraft flying outside of our MOAs even though we are well established within. Especially during supersonic runs. We are aware of the problems associated with a TCAS res and try hard to avoid it.
What are they cryin about???? I would have a rock hard chubby if a Viper joined up on my wing !!!!!!!! Prolly snap a few photos for posterity's sake...........
I will agree, for the fact that unbriefed or at least unplanned formations, have resulted in numerous crashes.
While I am not going to automatically accept the 20 ft off his wing claim, would there have been a reason to join up on him? This thread has turned into the debate of going into MOAs, and not the original idea at hand. I had a Flanker once use me for intercept practice, but at least he did not park next to me.
1. An MOA is shared airspace.
2. Both parties are entitled to be there.
3. Both parties have an obligation to see and avoid.
4. Neither party has the right to aggressively pursue the other one.
5. Neither party can legally fly in formation unless prior coordination is made.
If you're the one doing performance maneauvers it is your responsibility to make sure the area is clear. The guy flying straight and level has the responsibility to make sure where he's going is clear. It sounds like both parties did their part. The Viper called off whatever he was doing and the civilian was monitoring the area and his TCAS. Everything was good to go until the fighter stud decided to imitate Maverick. Bad call on his part. Sounds like his frustration turned into 'air rage'. Not good. I expect better judgement and a cooler head from someone charged with flying a multizillion dollar hotrod that could be loaded with all kinds of death and destruction.
