jstyle13
Reserve for life!
- Oct 16, 2002
Then ASA is the airline for you to apply to!
No longer do you have to worry about doing anything other than a low block 4 day! Jealous of senior FO's holding 16-18 day off 3 day trips??? Not here at ASA, everyone has the same amount of days off regardless of senority!! Tired of sifting through the bid packet, sorting out daylines, back to back 2 days and 3 days trying to find a line that allows you to plan your month around appointments/events/and things you want to do when your not lucky enough to be at work??? Not anymore!!
Come to ASA and never worry about bidding and sorting lines again! 5 minutes is all you need since a 12 day off 4 day is your only option. Thanks crew planning, your the best!!! And if you are skilled enough to get hired here and are lucky enough to become the number one FO on the list, then you will be rewarded with the single 3 day line availible out of 400+ lines!!
ASA, the working mans airlne!!!
Apply now!
Apply now!
