The DC-8 is easier to fly then the CRJ. Done both. When you put the 8 somewhere it stays there.
Surely you jest.
The only flight control that is hydraulically powered is the rudder, the ailerons and elevators are manually activated by means of anti servo tabs.
How many 767s are you guys planning to add? Will they be incremental to the current fleet or replace airplanes?http://www.jetphotos.net/viewphoto.php?id=6257114
It's currently in ILN having some avionics upgraded. ....Our second airplane was delayed by 45-60 days, meaning it should be out of the barn maybe Sept or so. There were stories of at least two more aircraft, plus some possibilities of two more which either are currently or soon will be farmed out to Cargo Jet. There was talk of us operating them, but I don't see it happening, at least not soon.
Is it true that one CAM 767 airframe was destroyed in Italy during the modification process?
