philo beddoe
- Jun 21, 2004
Only do it after you've recieved your willy nilly approach clearance, and are established on your willy nilly published route.philo beddoe said:Great job finding that.
I shall now commence willy nilly descents to all published altitudes.
"The devil made me do it."
I don't follow the logic, nor do I think it matters. I don't see any suggestion in the directives that would have me treat the altitudes any differently based upon radar coverage.philo beddoe said:That being said, I think the following logic applies.
If you flying feeder route you are very likely non-radar.
It follows that it is very unlikely that there is going to be another aircraft anywhere near you. If you are all alone in the area, it makes no difference if you descend to the feeder altitude or not, since you know you have obstacle protection,, and the only other reason to wait would be traffic separation.
(With this one caution: if ATC left you hanging a few thousand feet higher as you hit the feeder route, it might be wise to find out why.)
ILS RWY 02 BEAUMONT-PORT ARTHUR / SOUTHEAST TEXAS REGIONAL (BPT)RJFlyer said:As an example, I am looking at BPT (Beaumont, TX) ILS 12. There is a feeder frrom the BPT VOR (which is not an IAF) to the LOM, which is the IAF. The altitude listed on the feeder is 1700'. The profile view shows a descent outbound from the IAF on the procedure turn to 1700' (implying you should be above 1700' when you cross the LOM/IAF).
The question is, if ATC clears you to the LOM via the feeder, cleared for the approach, when can you descend to 1700'? When established on the feeder, or after passing the LOM/IAF outbound?
Hi PRPJT,prpjt said:The two clearances Tony gave are essentially the same thing. The controller wants you to stay at your last assigned altitude until HLI, then do what's on the plate. Only difference is that in 1 clearance he reminded you to stay at 3000 'til the VOR. Makes no difference if it's radar or not, it is what it is.
Ahh but Master, you did not supply a reference. So is the test "I personally believe it's true, so it's okay, but I don't personally believe this other rule, so it may not be."?philo beddoe said:Ahhh grasshopper, but those occur after the IAF, hence I am absolutely confident that they are part of the approach, therefore I am established for certain.
