Here's another - feeder route altitudes?
This looks like the reference you are looking for.
AIM 5-5-4
Pilot-
3. Upon reciept of an approach clearance while on an unpublished route or being radar vectored:
b) Maintains the last assigned altitude until established on a segment of a published route or IAP, at which time published altitudes apply.
"The question becomes, is the feeder considered a "published segment" of the approach?"
It is a published route. And after reciept of an approach clearance, when established on that route, published altitudes apply.
philo beddoe said:
Great job finding that.
I shall now commence willy nilly descents to all published altitudes.
"The devil made me do it."
Only do it after you've recieved your willy nilly approach clearance, and are established on your willy nilly published route.
philo beddoe said:
That being said, I think the following logic applies.
If you flying feeder route you are very likely non-radar.
It follows that it is very unlikely that there is going to be another aircraft anywhere near you. If you are all alone in the area, it makes no difference if you descend to the feeder altitude or not, since you know you have obstacle protection,, and the only other reason to wait would be traffic separation.
(With this one caution: if ATC left you hanging a few thousand feet higher as you hit the feeder route, it might be wise to find out why.)
I don't follow the logic, nor do I think it matters. I don't see any suggestion in the directives that would have me treat the altitudes any differently based upon radar coverage.
This approach, NDB RWY 09 Memphis Intl (MEM) shows two feeder facilities, GQE (Gilmore) and HLI (Holly Springs). Let's say I'm approaching HLI from the southeast (I just enjoyed a nice layover in Atlanta :)) and I'm cleared direct to HLI. I'm at 3,000', my last assigned altitude.
Two possible clearances:
1) "FedEx 357, Cleared the NDB RWY 09 Approach"
- - I continue to HLI at 3,000 feet, at which point I am legal to descend to the MEA of 2,100'. Upon reaching the LOM, ELVIS, I commence the procedure turn and begin a descent to 1,900'.
2) "FedEx 357, Cleared the NDB RWY 09 Approach, maintain 3,000' until established."
- - I continue to HLI at 3,000 feet, and then proceed along the HLI 299 radial outbound at 3,000'. I maintain 3,000' until I reach ELVIS because that's where the approach begins, and I'm not "established" until I get there. Being on the feeder route does not constitute being established on a segment of the published approach.
I could have received either clearance with radar coverage or without radar coverage. In either case I would transit quite near to Memphis International Airport, and would likely fly near other airplanes. I really don't see where you're getting the "non-radar" twist to the question.
The distinction that I think needs to be made is in regards to the clearance received.
Back to the post that began this thread:
RJFlyer said:
As an example, I am looking at BPT (Beaumont, TX) ILS 12. There is a feeder frrom the BPT VOR (which is not an IAF) to the LOM, which is the IAF. The altitude listed on the feeder is 1700'. The profile view shows a descent outbound from the IAF on the procedure turn to 1700' (implying you should be above 1700' when you cross the LOM/IAF).
The question is, if ATC clears you to the LOM via the feeder, cleared for the approach, when can you descend to 1700'? When established on the feeder, or after passing the LOM/IAF outbound?
ILS RWY 02 BEAUMONT-PORT ARTHUR / SOUTHEAST TEXAS REGIONAL (BPT)
Absent any other altitude constraints, you may descend to 1,700' once established on the feeder routing from BPT to BP (KAZOO - the LOM/IAF).
I was implying that even if you broke the rules, you would not likely hit anyone, not implying that the rules changed due to the presence or lack of radar servies.
"- - I continue to HLI at 3,000 feet, at which point I am legal to descend to the MEA of 2,100'. Upon reaching the LOM, ELVIS, I commence the procedure turn and begin a descent to 1,900'.
- - I continue to HLI at 3,000 feet, and then proceed along the HLI 299 radial outbound at 3,000'. I maintain 3,000' until I reach ELVIS because that's where the approach begins, and I'm not "established" until I get there. Being on the feeder route does not constitute being established on a segment of the published approach. " QUOTE"
Both scenarios are legal, as you say. But, for the sake of conversation, let's clarify the statement of not being "established". Once on the feeder you are established on a published route involved with the approach. Yeah, it's not actually part of the approach, however it is part of your approach clearance. The folks that publish the AIM thought the distinction was important enough to use all caps:
Approach Clearance
a. ..................WHEN CLEARED FOR THE APPROACH,THE PUBLISHED OFF AIRWAY (FEEDER) ROUTES THAT LEAD FROM THE ENROUTE STRUCTURE TO THE IAF ARE PART OF THE APPROACH CLEARANCE.
The two clearances Tony gave are essentialy the same thing. The controller wants you to stay at your last assigned altitude until HLI, then do what's on the plate. Only difference is that in 1 clearance he reminded you to stay at 3000 'til the VOR. Makes no difference if it's radar or not, it is what it is.
Agree with Tony C's interpretation
prpjt said:
The two clearances Tony gave are essentially the same thing. The controller wants you to stay at your last assigned altitude until HLI, then do what's on the plate. Only difference is that in 1 clearance he reminded you to stay at 3000 'til the VOR. Makes no difference if it's radar or not, it is what it is.
Hi PRPJT,
I think Tony brought up a great example. I do not agree with your interpretation of that clearance. I agree with Tony's interpretation however. The "Until Established" refers to established on the course prior to the FAF or final approach phase as supposed to established on the published route. Anytime that I have received a clearance that says a "maintain XXX cleared for the XXX approach" I have not received the "until established" part... but I would interpret it the way Tony did(Mostly in Mexico or South America). Still I agree, probably not "violation" material and not necessarily wrong...
philo beddoe said:
Ahhh grasshopper, but those occur after the IAF, hence I am absolutely confident that they are part of the approach, therefore I am established for certain.
Ahh but Master, you did not supply a reference. So is the test "I personally believe it's true, so it's okay, but I don't personally believe this other rule, so it may not be."?
Again, not being a wise guy. Just reiterating the point about differing opinions on 1+1=? Simple, basic, unless it conflicts with one's belief system. Then, all of a sudden it becomes a matter of opinion.
MMMDonut,
Why do you gotta be such an a$$hole and personaly attach people who have legitimate questions? Oh you know everything right? I thought so. Maybe anyone who asks is just stupid right? I thought maybe you had this belief. You need to get yourself a big fat mamma and shove it.
Because it has not been proven to me satisfactorily that the segment before an IAF constitutes being established on the approach with respet to altitudes.
Quote
Interesting. Tony I have always thought (and been told by an FAA Examiner after a 135 ride) that once you are "Cleared for the Approach" you can do whatever you want, as long as you maintain the altitudes prescribed for on the app. I did a feeder transition from a VOR to the LOM, then the Procedure Turn. Once inbound, I left my assigned altitude. He asked why I did not descend earlier after established on the feeder route. I told him I was cleared ILS 21 maintan 3500'. He claimed I could do whatever I wanted, descend to the altitude on the feeder radial, and descend again once established outbound. He also said that if I wanted to ARC off the VOR to join the LOC I could do that, as long as I stayed at or above the MEA or the MSA. Now, if you are cleared for the app. Via an ATC assigned route then all bets are off.
ATC does not seem to have a problem with this either, 10-degree turns off of enroute course to join the LOC at the destination is common.
So the question is? is the feeder a part of the approach?
Mark
From the horse's mouth
TonyC said:
...I'm cleared direct to HLI. I'm at 3,000', my last assigned altitude.
Actually you are established. The Pilot/Controller defines "established" as: To be stable or fixed on a route, route segment, altitude, heading, etc. Unfortunately, your controller is using non-standard phraseology by using the term "established" without additional informtion. According to the ATC Order 7110.65:
b. For aircraft operating on unpublished routes, issue the approach clearance only after the aircraft is: (See FIG 4-8-1.)
[size=-2]FIG 4-8-1[/size]
Approach Clearance Example
1. Established on a segment of a published route or instrument approach procedure.​
EXAMPLE-
Aircraft 1: The aircraft is established on a segment of a published route at 5,000 feet. "Cleared V-O-R Runway Three Four Approach."
2.
Assigned an altitude to maintain until the aircraft is established on a segment of a published route or instrument approach procedure.
EXAMPLE-
Aircraft 2: The aircraft is inbound to the VOR on an unpublished direct route at 7,000 feet. The minimum IFR altitude for IFR operations (14 CFR Section 91.177) along this flight path to the VOR is 5,000 feet. "Cross the Redding V-O-R at or above five thousand, cleared V-O-R Runway Three Four Approach."
Notice the clearances do not include the word "established" in either instance. If ATC needs you to maintain a particular altitude for traffic separation, the clearance would include a limit for that altitude. In the radar environment and receiving vectors, if ATC wants you to maintain an altitude until established, they need to inform you of established on what (i.e. localizer course, published route, etc.) Again from 7110.65:
Issue all of the following to an aircraft before it reaches the approach gate:
a. Position relative to a fix on the final approach course. If none is portrayed on the radar display or if none is prescribed in the procedure, issue position information relative to the navigation aid which provides final approach guidance or relative to the airport.
b.
Vector to intercept the final approach course if required.
c.
Approach clearance except when conducting a radar approach. Issue approach clearance only after the aircraft is:
1. Established on a segment of a published route or instrument approach procedure or see FIG 5-9-1 Example 1.
[size=-2]FIG 5-9-1[/size]
Arrival Instructions
EXAMPLE-
1. Aircraft 1 was vectored to the final approach course but clearance was withheld. It is now at 4,000 feet and established on a segment of the instrument approach procedure. "Seven miles from X-RAY. Cleared I-L-S runway three six approach." (See FIG 5-9-1.)
2. Aircraft 2 is being vectored to a published segment of the final approach course, 4 miles from LIMA at 2,000 feet. The MVA for this area is 2,000 feet. "Four miles from LIMA. Turn right heading three four zero. Maintain two thousand until established on the localizer. Cleared I-L-S runway three six approach."
(See
FIG 5-9-1.)
3.
Aircraft 3 is being vectored to intercept the final approach course beyond the approach segments, 5 miles from Alpha at
5,000 feet. the MVA for this area is 4,000 feet. "Five miles from Alpha. Turn right heading three three zero. Cross Alpha at or above four thousand. Cleared I-L-S runway three six approach."
(See
FIG 5-9-1.)
4. Aircraft 4 is established on the final approach course beyond the approach segments, 8 miles from Alpha at 6,000 feet. The MVA for this area is 4,000 feet. "Eight miles from Alpha. Cross Alpha at or above four thousand. Cleared I-L-S runway three six approach."
(See
FIG 5-9-1.)
I hope this helps, but it probably just more fuel on the fire.
Full of Foehn
