ReverseSensing
On the BC
- Apr 15, 2004
Boots on horizontal and vertical stabs, leading edges, engine inlets, electical props and windows.. can select fast mode, auto/ normal..
Just to be clear, you can select slow or fast auto mode or manual mode. Manual mode is (obviously) manual and not generally used for normal ops; auto mode used for all normal ops. Auto slow is a 3-minute cycle for all six boot sets; auto fast is a 1-minute cycle for all six boot sets. Slow or fast, the cycle is self-homing and will complete one full cycle before turning off, even if selected to off or manual.
There is an ice detection system, with 2 independent ice detection probes. When either probe detects ice, a message flashes on the engine display until the ref speeds switch is selected to INCR, which causes the message to stop flashing. It goes away when ice is no longer detected. Once the ref speeds switch is in the INCR position, the low speed cue, stick shaker and stick pusher calculations are modified accordingly.
