A350 said:SkyBoy:
It is a shame....it is also business.
Blame is a terrible thing......when you point the finger at someone, there are three pointing back at you.
If you think that Freedom and G0Jets were bad, wait until NEWCO gets up and running. There just is no defense for this stuff right now. Even a strike by the NWA pilots will not stop it. Leaving the cockpit at NWA just invites someone else to step in. Staying and flying is the only way.
A350
So Gayjets is just fine with you, but NEWCO is pure evil? What a dipsh!t!
As stated before, the problem is not that they are on a seperate certificate. Trans states Holdings did not have to use a different senority list for the new company. They could have and should have used TSA pilots for this company.
As for gayjet pilots, if they needed a job in STL why not work for TSA instead? Why take this job and help TSAH give thier current pilots the shaft in the A$$
Knowing that the company should have used the existing TSA pilots to staff the new certificate, how can you defend gayjets or the pilots that took the job instead of just going to TSA?
