ksu_aviator
GO CATS
- Dec 1, 2001
I don't believe so. I got them from Opera using wet runway. I don't believe Opera gives you factored numbers.
*edit*
I just double checked my numbers and settings in Opera and the same information keeps coming up. The wet, unfactored landing distances I posted above appear to be accurate.
Now, there is a SAFO that says if you don't have wet runway numbers from the manufacturer, you can use 15% on top of the 15% you are already adding...so a 2,194 dry unfactored would become 2,904 feet. But I've fiddled with Opera trying to get 2900 for a wet runway and just can't. Opera is telling me the unfactored landing distance at 13000 lbs is 4200 feet. I'll check the Tab Data later today, maybe the Tab Data is different?
Turns out my Opera numbers are factored...I don't know why. I can't find a way to change it.
