FLOPS Phenom overrun
NTSB Prelim
NTSB Identification: CEN13LA462
14 CFR Part 91: General Aviation
Accident occurred Monday, August 05, 2013 in Eden Prairie, MN
Aircraft: EMBRAER EMB-505, registration: N327FL
Injuries: 2 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. NTSB investigators may not have traveled in support of this investigation and used data provided by various sources to prepare this aircraft accident report.
On August 5, 2013, at 0848 central daylight time, N327FL, an Embraer S.A. EMB-505, multi-engine turbofan airplane, was substantially damaged during landing at Flying Cloud Airport (FCM), Eden Prairie, Minnesota. The two pilots were not injured. The airplane was registered to and operated by Flight Options, LLC; Cleveland, Ohio. Day visual meteorological conditions (VMC) prevailed at the time of the accident and an instrument flight rules flight plan had been filed for the 14 Code of Federal Regulations Part 91 positioning flight. The airplane had departed Pittsburgh International Airport (PIT), Pittsburgh, Pennsylvania, about 0730 eastern daylight time and was destined for FCM.
The pilots reported that the airplane was on a steep visual approach when they landed long and fast. The pilot flying also reported that after touchdown he could feel the pulsing of the anti-skid brakes but was unable to stop on the runway surface. The airplane departed the end of the runway and impacted the airport boundary fence coming to rest on a four-lane highway about 1,000 feet from the runway.
At 0838 the data from FCM revealed that the wind was from 150 degrees at 4 knots, 6 miles visibility in mist, few clouds at 200 feet above ground level (agl), an overcast ceiling at 7,000 feet agl, temperature 18 degrees C, dew point temperature 17 degrees C, with an altimeter setting of 29.89 inches of mercury. Remarks indicated that rain ended at 0819 with a one hour precipitation of 0.01 inches.
_____________________________________________
Again, sad to see, and glad no one was hurt.
There is flaws with that plane. One contributing factor is not being able to use full flaps on landing.
Not for nothin', but the flaw in this airplane might have been the steep and fast approach. (See previous post)
Can you say "stabilized"?
Can you say "go around"?
We don't know the cause yet, but like you said, it's starting to look like another in the long list of unstabilized approach => runway overrun accidents. These make up about half of all jet accidents (not to mention all the ones that don't get counted because of less than substantial damage). We've all done it, and most of us have gotten away with it every single time - knowing we're outside of the stabilized approach window, but making the decision that we can salvage this one and pressing on anyway. Some of us have scared ourselves with a close enough call that we'd rather endure a go around that take that chance again. I don't know when we as a professional industry will really accept that go around doesn't equal failure, but we're not there yet. It took FOQA snitch boxes to get this across to the airline industry (and they're certainly not 100% there either). Most unstabilized approaches don't lead to overruns, but almost every single overrun starts with an unstabilized approach. Flight Options learned this lesson back in the day with 2 accidents in 2 years at BWI and CGF, hope this will help them remember, and maybe this will make the mgmt think twice before they shorten the field length for the Phenom again (though this runway should have been plenty long enough, cutting margins increases risk).
If they were fatigued, then why not call in fatigued? It happens often at nj. No questions asked.
You know as well as I do that few pilots are very adept at recognizing the symptoms of their own fatigue.
Fewer still are adept at acting on it.
And fewer still (thankfully) abuse the system thereby making legitimate fatigue calls more suspect in the eyes of colleagues and management.
All sad. And all true.
there was something on flight recorder, they knew they're busted so why not just admit it instead of lying.
They were probably discussing the unstabilized approach all the way in.
Sometimes saying nothing at all goes a long ways...
a stall on final means death. plenty of accident reports that prove this
gusty winds require adding speed to ref
wet runway equals roughly double the stopping distance
lets not rush to judge the pilots until we get all the facts
Don't know where you came up with those calculations. AFM wet landing distance divided by .6 times 115% does not double your landing distance and is preflight planning only. The underlying factor of this whole debacle is managements unrealistic demands it places on its overly worked pilots. These guys unfortunately stepped into it.
On a higher note Flight Options L.L.C. has recently been named by the Forbes 500 list as the top employer to QUIT! The only way to protect your certificates at this point.
135
oh yes sir
and you don't know this?
You might want to get into your uniform at the hotel and study the regs
Regardless of whether you are using AFM distances or factored landing distances (60%) for 135 the penalty is still 15%. Apples to apples. Now if you're comparing part 91 dry to part 135 wet...then in this crazy world you live in you're right, landing distance is almost double. Apples to pomegranates.
Class dismissed
Class dismissed
Good summary!
funny
I mean if you are really interested in safety would you not take the worst case scenario? and go from there
Of course. When I run the landing distance for a wet runway, I use the contaminated tables for snow.
Muppet.
Wrong again loud mouth dumbazz, its AFM DRY distance divided by .6 times 115 percent. Why dont you contribute some accurate information instead of your constant druel.
funny
Sure-worse case would be mlw (nowhere near) and 3,500 feet of pavement, both of which should allow for plenty of stopping distance.
Duh, one that does not meet the criteria for a stabilized approach. All of the outfits I worked for had very specific definitions.
Define an un stable approach?
Stabilized approach was defined by every company I worked for as "landing configuration, Ref and 10 at 1000 AGL in IMC and 500 AGL for visual approach".
High and fast does not fit the definition regardless of aircraft configuration.
Seriously???
Any approach that does not meet the criteria for a Stable approach. While most operators have their own specific criteria, In General...
Prior to 1000' in IMC or 500' in VMC:
The aircraft is on the correct flight path;
Only small changes in heading/pitch are necessary to maintain the correct flight path;
The airspeed is not more than VREF + 10kts indicated speed and not less than VREF;
The aircraft is in the correct landing configuration;
Sink rate is no greater than 1000 feet/minute; if an approach requires a sink rate greater than 1000 feet/minute a special briefing should be conducted;
Power setting is appropriate for the aircraft configuration and is not below the minimum power for the approach as defined by the operating manual;
All briefings and checklists have been conducted.
Specific types of approach are stabilized if they also fulfil the following:
ILS approaches must be flown within one dot of the glide-slope and localizer;
a Category II or III approach must be flown within the expanded localizer band;
during a circling approach wings should be level on final when the aircraft reaches 300 feet above airport elevation; and,
Unique approach conditions or abnormal conditions requiring a deviation from the above elements of a stabilized approach require a special briefing.
An approach that becomes unstabilised below 1000 feet above airport elevation in IMC or 500 feet above airport elevation in VMC requires an immediate go-around."
