Falcon 50ex
c140
The Boss-man is looking at up-grading to a Falcon 50ex... What are the pros and cons, any other information on the plane would be appreciated.
Thanks!
What an jerk. Is he a Flt Opts beech driver ?
EX is amazing. Burns much less then staight 50. Climb performance is excellent.
The 50EX is a great plane. Expensive to maintain, but they don't break much. Built like tanks.
The EX will go 3000nm at .80, no sweat. You'll love the bird.
I have been flying the DA-50EX for 4 years now. Overall it is a great aircraft for the money. I have not had many problems with it.
In our fleet of three we have had a few engine failures (the TFE-731-40 engine has some problems with a carbon seal and turbin blades cracking, do some research on that). There is also a problem with leaking Fuel Control Units (I have had that one), failure of the oil bypass valve (expensive to replace because you have to remove an outboard engine to get to it, we had three of those this year for some reason) and a failure in an oil return line that is covered by AD (it cracks and leads to an engine shutdown due to low oil pressure). The problem with this aircraft is really with the engines.
The aircraft itself performs well. Great short field performance, good second segment climb numbers, great range. The cabin is not all that big, the max pax for comfort is 6. Plenty of baggage space (not big enough for skiis though). I made it from KBUR to Atlanta today at M.83, FL 390, burned around 9,000 lbs of fuel, average 40 kt tail wind, 3.5 hours flight time, landed with 4000 lbs of fuel (still had room for 2,000 lbs more fuel if I had needed it), I could have carried 9 pax.
Overall, it is a lot of aircraft for the money.
Also to consider c140 is a straight 50 that has been converted to the -4 engine config.
Talk to the folks at Premiere Aircraft. The advantage of this route is you may wind up with an equal performing aircraft for less money.
But there is no free lunch....these will be older airframes that will need other work.
The smart money will likely go with lower time and newer airframes vs. older airframes and higher times.
YMMV.
rumrnr78 and that darn challenger 300! hahahahahaha! I agree. Forget the Falcon. Too small. But challengers more $$$ of course. I hear the Legacy can be had for around same price, and man what an aircraft!
That's is very interesting about the engine deal on the plane...
The boss has looked at the cl-300 and the citation X, he seemed to like the fa-50 better... But I don't know.
How about out of those planes, how do they perform out of a hot and high airport?
A 50EX is a good hot/high airplane. I suspect a CL 300 is as well, but can't speak for the X.
Be wary of the CL300...while it's a good bird, you have to deal with the Bombardier support network, and it's WAY LESS than stellar.
And right now, if you even want a CL300, you're gonna put out 23+mil for one that occasionally comes on the market...or wait 3 years for one that you order now.
Nothing beats the Falcon for hot and high. 3 engines cant be beat. Climbs like a beast. Lose an engine and just keep going. Not an emergency, just an abnormal. 2 SEPERATE pressurizations sys. No chance of CG problems. Shown to fly at MAch .97, not recommended. Good support and resale value. Never had engine problems on EX. Had 2 bad fuel computers on straight 50.
Legacy is loud inside and has a narrow cabin. Its a streched Brasilia 120 Turbo Prop fusalage. Not impressive to fly in. Ask passenger and pilots and you will see. Flt. Opts has them.
Better watch out for LegacyDriver!! That last paragraph is going to send him reeling, LOL!
falcon 50
The citation 10 was okay when it was hot, but not at high altitude, like aspen, etc. It was fine on two engines, but we always wondered how much scrambling we would have to do if we canned one 1000 above the ground. Great performance, 6 pax okay, lots of bag space. Maintenance, from what I have seen is probably comparable, although when it was wet and cold, got many computer ghosts, that would eventually disappear, like most ghosts do.
Maybe you should look at the C-680 Sovereign. I would take that over the X. I flew one for about 6 month before we finally sold it. It basically has the same cabin as the X, great high hot and short field performance. Never had any problems with it. The only drawback is it is really slow (M.78 cruise), like a Hawker but with a lot more baggage space.
Narrow cabin????? You think the Legacy cabin is NARROW???
Legacy Cabin is probably twice as wide. It sure as heck is up front. Man, what a warped view if you think the Legacy is narrow compared to a 50! HA HA HA!
Legacy beats the hell out of a Falcon. The only thing a Falcon has going for it is engine out climb.
50EX:
- Burns the same gas as the EMB and at max. payload has shorter range.
- More expensive to maintain and *ALWAYS* broken. The thing is just old. If I tried to do in 50EX what we did in the Legacy we'd be in a service center within three days.
- No FADEC.
- Smaller. (If you're a French midget it's perfect for you. Me, I'm ready to kill myself after about 2 hours in it.)
- Louder (You think a Legacy is loud, try a Falcon. The gaspers will make you deaf.)
- Environmental sucks. Overheat the ducts... Always feel cold at altitude because the windows don't have any conditioned air blowing on them like the EMB has. (EMB surrounds you with conditioned air and puts out way more on a hot day than Falcon, also.)
- X-Wind Performance is abysmal.
- No foot pedal steering.
- Non-linear tiller. Ridiculous.
- Under-ruddered.
- APU not useable in flight.
- Half-assed glass cockpit.
- DV Window Weak. (Someone breaks the heater about every fourth time they close it.)
- WSI capability terrible. Reception bad.
- Draining potable water a nightmare (vs. pulling one lever on an EMB).
- Baggage Compartment - TINY. I don't know what they think will fit in there that can meet the weight limit. You can barely get enough bags in there for four people much less 8. (Legacy baggage compartment frickin' HUMONGOUS.)
- Fuel Gauges SUCK (No totalizer and always off by 500# one way or the other.)
- Fuel system a clusterhump.
- Electrical system (see above).
- Climb at ALT not that great. Legacy actually climbs better from the 30s on up.
- No Ice Detection.
- No Trailing Link Gear.
- Airplane dumps fuel all over the ramp when vented for fueling.
- Ergonomics particularly night lighting horrendous. You get some lights dim and other lights bright no matter how you try to adjust them. Also reflects off the glass which is just annoying as heck.
- No EICAS
- AOM and AFM are ridiculous. They are as many volumes as an encyclopedia and they tell you NOTHING about the airplane.
As a buddy of mine said about the 50EX, "They may as well put a tail wheel on it and get it over with."
The Embraer is 1000 times more durable, far more comfortable, reliable, and redundant. The 50EX has an extra motor but as often as they like to crap out (listening to the people at FSI you'd think this happens 100 x a day) I'd say it probably needs it.
MTOW runway length for 50EX is like 5,570' vs. 5,980' for the EMB. Not that big a difference.
As for the noise... The only time the EMB is noisy is above 300 knots with all the doors in the cabin open. You keep the galley and cockpit doors closed and it is fine. The 50EX is loud everytime you push the thrust levers up, and I don't care what anyone says, I've yet to see an airplane that's really "quiet" above 300 KIAS.
Yes the Falcon will do 370 KIAS, but I don't consider that useful for much other than burning gas.
Yes the 50 has coupled VNAV. But ergonomically it is horrible, cramped, and uncomfortable.
Unfortunately, EMBs have over 2000# of titanium in the spars, wings, and pylons. The price has rocketed through the roof on that and the asking price for the Legacy 600 is now over $25M. A Falcon 50EX is pretty competitive on acquisition cost at that price.
Having flown both extensively I would pick the Legacy over the Falcon every single time.
Time has passed the Falcon by.
As a buddy of mine who used to sell them said, the most common Legacy customer was an ex-50 owner. The Legacy is a great airplane. Hopelessly underrated.
Embraer Legacy not perfect and I can give you all her faults...but she abuses Falcon 50EX like the ghetto.
Oh well, the paycheck is bigger on the 50EX I guess...
Thanks for pointing it out to me.
For my money, time, technology and the Legacy conspired to kill the 50EX. The Falcon 2000 didn't help any either as it is said a 2000 is cheaper over five or ten years than a 50EX to operate even though it is more expensive to buy.
The EMB is one tough airplane. Way overbuilt. Totally trustworthy with no gotchas... By far the most reliable airplane I've ever seen.
Now I'm gonna' go get my popcorn.
wow LegacyDriver you do know the Legacy....
How is the market for finding a legacy?
What about a falcon 2000 that has been mentioned a few times?
The bossman could afford a BBJ if he wanted but he is new to the aviation world and is feeling it out slowly.
Ask anyone and they will tell you that while I may not be the most popular guy on here I definitely know that airplane. (Not so much now as I haven't flown it in two years, but I still remember a lot.)
I saw one of Flight Options LX airplanes for sale. Was I think $21M.
If he gets the Legacy drop me a line and I'll fill you in on all the gouge.
It's a great airplane. Easy to find one for sale... The wait on new ones isn't too bad. You won't be disappointed. The Legacy 600 is now advertising 3,400 NM range as well. Not bad.
Falcon 2000 I don't know. If you get one make sure it is an EX. Like all Falcons the 2000 is not a good crosswind performer. Watch out.
I will not argue that ... I was just wondering if you added a type to your cert.
But more importantly, are LD flight crews still getting payed regional wages, or have they raised the bar to that of Falcon?
My previous Legacy operator employer pays about $5000 more per year than I make on the Falcon 50 at my present employer.
And that's probably about twice what an RJ driver makes.
I have a friend who made $201,000 NET last year flying the Legacy. Not sure of any Falcon jobs that do that.
Frankly that doesn't matter any way as my chances of getting a violation or an incident are much higher in a Faclon than an Embraer. All the promised salary in the world is no good to a pilot with no license. The Legacy is safer, tougher, and more capable where it counts than a Falcon is because it is derived from an airplane that has to work every time.
Hey Rum, having any luck with that gear problem on your Falcon? How many days are you gonna be stuck?
50EX:
- No FADEC.
- Under-ruddered.
- No Ice Detection.
- No EICAS
I almost never post here but as you are leading someone down the wrong path, I can't help it.
1st. It's clear your 50 is a piece of crap. Ours has none of the issues you are speaking of (gaspers, dv window heat, etc..)
2nd. It's clear from your comments that you are in a straight 50, not an EX.(rudder, electrical sytem, fuel system, totalizer, etc...)
3rd. The Leagacy in our hangar (3 months old) has an abysmal dispatch rate. We have failed to dispatch once in the last 1600 hours of flight time. They fail average of twice a month.
c140-Legacy Driver is just a little biased;)
Price isn't the only reason the airplanes aren't as popular. Do research on the airplanes. You may find that a Legacy works best for your mission, you may find, as most do, that another airplane works better. Hangar space, for one, comes to mind as a biggy...
As always, MHO
$201,000 net would be great if you like living in the middle east. Who makes that kind of cash in the US? Im sure there are falcon jobs in the middle east that pay just as much if not more.
Also, how does the airplane increase your chances for violations??? This makes no sense at all, but whatever floats your boat.
Ive flown both EMB and Falcons and would much rather fly the DA products. They're a proven product that have been around much longer than any "taco jet".
I've laid out nothing but facts.
Piece of crap? We have two of the last five built in addition to three others. Are they *ALL* pieces of crap?
Oh really? When did the EX get a fuel totalizer?
And you have none of those issues? You don't pee fuel on the ramp when you vent it? Your airplane has an EICAS? Really? You got ice detectors? Nice. You can use APU in flight? You have a linear tiller? Footpedal steering? Outstanding X-wind performance? Please.
Come on now. **BS Flag**
All five of ours are EXes, BTW.
Obviously they don't know how to operate it then because I've *NEVER* heard of *ANYONE* with that experience. You got a tail number? I'll verify it.
I flew almost 4,000 hours split about equally between ERJ and Legacy. I failed to dispatch ONCE in an ERJ (NEVER in a Legacy) and I could have gone. My F/O expressed the *SLIGHTEST* bit of discomfort and I said, "That's it then," and called MX.
No, just realistic. Falcons are overrated POSes and I'm not afraid to say so. The Legacy is a great airplane. People just don't feel like taking the heat to say it. Well I don't mind. I've got thick skin.
As always, MHO
I do agree with you here in part that another plane may work better for your mission, but "MOST" people just let their egos get in the way. An airplane is a BUSINESS tool. How it looks on the ramp isn't as important as what it costs.
The Embraer has sold nearly 150 airplanes in only about 6 years (compared to the 50 the Legacy has sold nearly 50% as many airframes in only about 20% of the time). That's quite impressive when one considers it entered a crowded market right after 9/11/2001.
The airplane is *AWESOME*. Don't let anyone kid you.
A proven jet that's been around much longer??? How does that matter? Being around for calendar pages doesn't prove as much as time in the air. The Falcon 50 would *NEVER* hold up under the workload the Legacy took at my last job. The Falcon *would* spend more time in the hangar than the Legacy though.
In terms of calendar pages the 145 series has been around twelve years. The EMB-120 and EMB-110 were proven performers in their day, too. This isn't Embraer's first rodeo.
The Embraer 145 fleet now has TEN MILLION hours and counting and somewhere around 1,350 airframes in service with no fatalities aboard them. How many hours does the Falcon fleet have, in particular the 50EX?
See, that's precisely the problem with the Falcon. They've been around a long time and they rely on OLD technology and OLD ideas. The Embraer got its start in 1996. The Falcon is based on 1970.
The Embraer beats hell out of Falcon and anyone who thinks otherwise is not thinking rationally, IMHO.
To each their own.
