pacsky72 said:AirTrain from EWR to Penn (one transfer), then find your way to the N train, take that to end of line and then hop on the M60 bus which stops at every LGA terminal...dat be the cheapest.
Hair-on-Fire said:I think i can beat you on cheapness. You can take the NJ Transit bus (#62) from EWR to Newark Penn Station and transfer to the PATH train. Take the Path to 34th St. and then transfer to the N train to the M60. I'd do it your way, but you never know with Pilots, right?
Bus $1.25
PATH $1.75
Subway 2.00 (free transfer to Bus)
IFlyLow said:That way is good until 34 st Penn Station, but don't take the N train to the M60, that takes WAY too long with way too many stops. Plus the N doesn't even go through Penn Station - it's a couple avenues away.
Get on the E from Penn Station. E is an express train to Jackson Heights, then take the free transfer there to the Q33 bus through Queens. Short bus ride to LGA, and an express subway - can't beat that.
greenpickle said:Is there an easier way that isnt horribly expensive?
Propsfullfwd said:you can save a 1.25 if you want to catch the Robert Treat hotel van from P4 and walk to Newark Penn. it is 2 blocks...
props
Jimdandy said:man how do people live with all that hussle and bussle. Are the chicks at least hot.
aa73 said:Believe it or not, a lot of times when I have to go from LGA to EWR and I have more than 5 hours, I j/s up to BOS and then j/s down to EWR. A lot of times it's faster and there's no hassle with trains and buses, you can sleep on both flights... and it's FREE! sounds crazy but works like a charm.
73
73
