Stifler's Mom
MILF...MILF...MILF
- Oct 12, 2003
Hahaha...Bow wow wow, yippie yo, yippie yea!Stifler's Mom said:Ah geez, the dog with the goggles has logged onto FN FAL's computer again.![]()
Milkdud99 said:i do see ur point, its funny how it is called an engine fire, but really the engine will probably never catch on fire, the only TRUE engine fire is when the metal catches fire... which i'll bet alot of money that its never happened with a recip...
Yeah, but the alloys used in engines are dumbed down pretty good for exactly the reason you're referring to. About the only time it'll catch is if there's a MUCH bigger fuel fire around it - like after a crash.A Squared said:Nope, not true. Many recip engines contain quite a bit of magnesium, which burns really really well once you get it going and is very difficult to extinguish, almost impossible. And yes, the magnesium does catch on fire occasionally.
TIS said:About the only time it'll catch is if there's a MUCH bigger fuel fire around it - like after a crash.
avbug said:Actually no...metal isn't dumbed down at all, can't be. The alloys in many light recip engine cases are largely magnesium, and yes, they do make great class D fires.
What makes a fire hot enough to go there? How about a forced air fire? Like, say, what happens in an aircraft in flight?
Never seen burned and melted components in an engine compartment? I surely have, with spatter all over the place. Get a good oil or fuel fire going up there and don't control it, you could have a real problem, including a class D fire.
I know, I know. But you guys are talking about big, multi-bank radials and that's not what my original answer was referring to at all - and I think you both know, or should know that. The guy who asked the original question is a long ways from needing to know anything about big radials. I doubt he's ever seen one perform at top end at Reno.A Squared said:No, not true, I know of several which happened in flight. At least one was an accessory section on an R2800 which resulted from a bearing failure and burned from the inside out.
wxman13 said:Speaking of fires on startup, since these sound like they can be very serious...
Most aircraft emergency checklists that I've seen (single engine pistons) call for continued cranking on a fire at startup, then mixture idle/cutoff, fuel off, etc. How effective is that sequence in reality, versus just shutting off the fuel, turning off the ignition, and running far from the plane?
Peter
