777forever
- Dec 18, 2007
Cleared for approach and you get an engine fire while joining the LOC. WWYD?
_________1) quickly brief a s/e approach.
2) have the pm run through the qrh for an engine fire while ...
3) bugging a s/e flap setting and configuring on your own while ...
4) declaring and informing atc you cannot take a go-around.
5) quickly brief the f/a's that there is an engine fire, you're expecting a normal landing in (1, 2 .. Minutes) but be mentally prepared for an evac.
After landing ...
6) ascertain whether the fire is still in progress and if so, evacuate.
7) if not have cfr inspect aircraft before being towed to a remote location for orderly egress.
8) call alpa, your cp (brief synopsis,) otherwise keep your mouth shut and file an asap.
9)after your testing proceed to the hotel bar, drink heavily and later be fellatioed by the females you saved.
Grow a pair - then decide if you want to cover your @$$ or save your @$$.
For me: outside the FAF, declare emergency, run QRH. Inside the FAF - declare emergency, land.
Are you really an airline pilot? What kind of question is this? If you have any type of fire onboard or suspect any type of fire, you declare an emergency and land ASAP. If you don't have enough time to complete the appropriate checklists, you still land ASAP. You should know how to configure your aircraft for a single engine approach without using a checklist. If not, you shouldn't be flying that aircraft.
WWYD?
CA1900 said:Shoot the hostage.
I see what you did there.
"Say goodbye Harry!"
So you wouldn't land immediately if the fire happened outside the FAF or are you just saying you would run the QRH and land immediately outside the FAF?
As stupid as you all think the OP's question is, I've had to commandeer the airplane during two separate lofts now with smoke/fire (or possible fire) on board after the CA wanted to hold or execute a missed approach. Maybe that was with a couple of you on here.![]()
