PHX767
it's a dry heat
- Dec 2, 2001
I have a couple hundred hours of dual given in the Seminole, so I thought I would chime in to this thoughtful discussion.
Re: The new MEI's comment that his examiner said he always accelerates to blue line before gear retraction - I ask, what is blue line? Best engine out climb speed, right? How does this relate to Vmc and control of the airplane? Please be aware that Vmc is an everchanging speed dependent on a lot of factors, the gear being one of them. Why not attain Vmc, be able to fly if you lose one, then retract the gear and pitch for at least Vyse + 5-10.
Here's a question to muck up the works - Will the prop feather if the engine stops?
Are there anti feather pins on this plane? How about other light twins you are flying?
I was well versed in all the factors that affect Vmc when I was an MEI. When I trained pilots in a larger turboprop, I met Vmc a few times every night, especially when light, on a single engine miss, and then the student called for Gear up. I could tell by how far they had the yoke cranked over to keep the wings level how close we were to the edge.
