Holding Short
Active member
- Mar 19, 2006
"We're departing runway 12 at Podunk. It's day, VFR conditions, with flaps up. Prior to liftoff, we're going to abort for any malfunction. Between liftoff and moving the gear switch to the "up" position, we're going to abort only for engine failure, engine fire, or loss of directional control, continuing straight ahead with whatever runway is available, rolling out onto the nice grass off the end (although we will take out several approach lights). Once the gear switch is in the "up" position, we will treat malfunctions as airborne emergencies, and either return here to runway 12, or to Big City International Airport, where they have prettier fire trucks. Any questions or comments?"Holding Short said:Could someone post a sample pre-takeoff brief exactly as they would do it for the same senario we're talking about?
Remember...this is probably the language used by the 2 CFI's who wrecked the airplane for training purposes.AC560 said:Another consideration I would make in whether to chop the power and drop from 75’ or go would be any systems lost off the failed engine.
MauleSkinner said:Remember...this is probably the language used by the 2 CFI's who wrecked the airplane for training purposes.
David
AC560 said:I don't understand the point of your comment.
If you tell somebody to "chop and drop", they're gonna "chop and drop", which is how you get enough impact in this situation to total an airplane. If you tell someone to "land straight ahead", they are more likely to land the airplane under control, with minimal damage.AC560 said:Another consideration I would make in whether to chop the power and drop from 75’ or go ....
MauleSkinner said:Sure, a proficient pilot SHOULD understand what you're talking about, but literal interpretation of comments like this is what keeps lawyers in business.
Sig said:Gear down? Runway ahead? Don't TOUCH A THING, maintain directional conrol and land that pig (you have to point DOWN to accelerate to 88), close throttles in the flare (you lose so much lift *LIFT* that the plane needs when you reduce power on the operating engine). This is a Seminole, not a Baron- procedurally it's a suicide on the go if you munch a motor that soon.
Hit something soft and cheap. All of this gets really scary on a hot day. It descends nice and gently with one feathered, clean, and blueline at 2500' when it's above 92 degrees and humid. God, I don't miss instructing in Dallas in that machine.
UndauntedFlyer said:So does the gear position, up or down, really make a difference in the decision to continue or abort. Not to me. And it shouldn’t make a difference to anyone else if the gear can be moved up or down in seconds. Therefore, decisions to continue should be made on known AIRCRAFT PERFORMANCE CAPABILITY, not gear position.
Personally, I have found the PA-44 (Seminole) to be a weak but a satisfactory performer when I have done the engine failure on takeoff simulation from a 3000 foot AGL simulated hard deck. In other words it will climb out at 200 fpm following an engine failure from the after takeoff scenario.
I agree...there's a BIG difference between a demonstration at 3000 feet and the real thing. That nice 200 fpm climb rate is what, an 800fpm sink rate with prop windmilling and gear down? Add another couple hundred fpm sink rate in an airplane like a Baron for the gear in transit (extra doors open)?Sig said:Seen it, done it, not much to hit when you're at 3000. Gear position absolutely makes a difference in that plane regarding a go/no go- Those seconds in transit while your attempting to acheive a climb speed equals a downward trend to that huge hard thing where the wreckage will be found. So you pull the gear up, no performance from the machine, and you're hurtling towards the buildings, trees, anything else that you now have to clear with a handicap and a slow climb. Blueline into the trees or gear stays down, point down and land immediately? On top of all of that, you bring it around (more obstacular interference)- plenty of opportunity to make a hash of it.
Indecision abounds when you're talking about a plane specifically built for training. You have more time over the outer marker than most have total, and someone like you wouldn't have much of a problem at all in it- because you're not just a professional pilot but a HECK of a HIGH TIME professional pilot. But slap a real failure on the shoulders of a guy with 0 time in twins, the instructor might be put in a place he can't get out of. Look at who we're talking about here- myself included- as far as the basic demographic that's flying these.
The cowl flap penalty alone in a Seminole is pretty sick. It's anemic on the best of days!
In my personal experience, people tend to either:UndauntedFlyer said:A follow-up question for this thread is this: Why do we have so many engine-out upset (roll-over) types of crashes for twins after takeoff?
Then, the airplane made a steep left bank, rolled inverted, and nose dived into the back porch of a home.
Cary said:I'm not a twin driver, but I can read. The statistics speak for themselves, that attempted continued take-off with only one engine is much more likely to result in a crash than resigning oneself to landing straight ahead. The average twin driver is just not that proficient in emergency single engine operation.
Cary
UndauntedFlyer said:Engine failure after takeoff: Apply rudder, level the wings while pitching forward to maintain airspeed, retract the landing gear, feather the prop and climb out. This is really not a difficult task in terms of airmanship. What it does take is a predetermined plan of action (POA) in your mind just prior to takeoff. Without this POA the result may be the Vmc upset you mention. Therein lies the cause of the "statistics that speak for themselves" as you say. It's the "Deer in the Headlights" syndrome that kills people. Pilots with no plan are at risk on every takeoff. If a pilot has a "Plan of Action" for engine failure after takeoff and considers runway length, obstructions, terrain and performance, then there is no reason for any pilot to experience a Vmc upset.
If aborting the takeoff and crashing off the end of the runway was the only plan I would likely look for an alternative such as changing runways or maybe taking off at a lower weight. If performance is the problem because of high density altitude then there isn't much that can be done. If that's the case, only then is the plan of action following an engine failure just after takeoff to reduce power, abort the takeoff and make the best of this bad situation. If a pilot flies light twins from high density altitude airports there is always a performance risk that can not be overcome except with turbo-charging.
dhc8fo said:In my 340, if I had a 10,000 foot runway, my gear would still be down at 75 feet.
I like your points, but there is one you miss, and it drives me crazy. I see it at DVT all the time by the academy aircraft and its only a matter of time...UndauntedFlyer said:Let's talk about retracting the landing gear after a normal takeoff.
UndauntedFlyer said:Sometimes I see pilots on their tests trying to trouble shoot with the throttle all the way back, then announcing that the engine would not restart and feathering. This is totally unsatisfactory performance because when the throttle is all the way back the pilot is unable to see if the engine has actually re-started as a result of their own trouble shooting efforts.
acaTerry said:While I agree in theory with your use of the prop control (which IS a dead giveaway of the engine), it is no more useful than a carefully retarded throttle. If done correctly, no significant risk is taken by a smooth, careful pulling back of throttle.
acaTerry said:Also, you make a good point that too often gets looked over, and that's aircraft control...too many times pilots go to their death performing actions of procedure while letting the airplane run away from them.
Comments/questions?I see this many times when I am testing a multiengine applicant who is only prepared for what he or she thinks is the usual simulated engine failure after takeoff. What I mean is that some applicants are only prepared for the instructor/examiner to simulate an engine failure by bringing a throttle back at about 600 - 800 feet AGL after takeoff when the landing gear would already have been retracted and the power reduced to climb power. After the examiner brings back a throttle, the applicant mumbles a few things such as, “Mixture, props, throttles, gear-up, flaps-up, verify and feather.” Then the examiner moves the throttle and prop and announces that “zero thrust” is set. In my opinion this whole scenario has very little realism to an actual engine failure just after takeoff at 50, 75 or 100 feet with no runway ahead and no where to land.
Instead of testing with the above scenario I prefer a more realistic simulation of a real engine failure after takeoff. As I have mentioned earlier in this thread, I prefer to climb to 3000 feet AGL for the safety of a simulated hard-deck takeoff with the gear down, full power and airspeed between Vxse and Vyse or, Vsse if such as speed is published. With a mixture cut at 50 feet above the simulated hard deck, all that’s required is to apply rudder to maintain directional control, level the wings while simultaneously pitching forward to hold airspeed, then retracting the landing gear and feathering (for real) the propeller. This simulation is realistic. Every instructor that knows me and how I test this task prepares their students for this simulation. Almost all applicants pass this task by clearly knowing the correct action following an engine failure after takeoff. They have a clear plan of action for this emergency. And as for performance, all modern training twins such as the Seminole and the Duchess climb out with no difficulty.
On the other hand, if I happen to have an applicant for testing that is recommend by a CFI outside my area who might be unfamiliar with the 3000 foot AGL hard deck method, those applicants perform similar to a “Deer in the Headlights” following the engine failure after takeoff. They are startled and do nothing for a short while and then they start mumbling something about mixtures, props, throttles, checklists, carb heat, boost pumps, flaps and so on (even though all of these were set for takeoff and don’t need change). This brings an element of confusion and second guessing until so much time is lost along with airspeed. Of course, the next thing we know the airspeed has deteriorated to very near Vmc causing examiner intervention for safety of flight. That check ride is over.
So you see, what is necessary to prevent the “Deer in the Headlights” roll over accident is a clear plan of action for an engine failure right after takeoff. If the runway is less than about 5000 feet it would be very difficult to abort a takeoff once airborne and above 50 feet. But if you know the airplane is light enough and the performance will be satisfactory, then be prepared to do exactly what is necessary and don’t perform actions that are unnecessary for that takeoff that day. For example don’t talk about or try to retract the flaps when they aren’t being used for takeoff. Have a clear plan of action and review that plan in your mind before takeoff:
Having a clear plan of action will prevent the “Deer in the Headlights” syndrome which is the cause of Vmc roll-over (upset) accidents.
- Maintain directional control while pitching forward to maintain airspeed
- Retract landing gear
- Verify and feather prop
- Maintain at least Vxse, or Vyse if that speed has been obtained
UndauntedFlyer said:Ok then, the question is: Can this takeoff be made safely following an engine failure at 75 feet?
Comments please.....
jws717 said:according to gidance givin in the new seminole manual, continued T/O below 75 kias is impossible.
The new manual also gives the performace hits for things like gear retaction, flaps out and prop windmilling, Doing some simple math for a seminole in average conditions.
(s/e roc) - (performace hits)= negative ROC untill the gear is up and the prop feathered. at the negative rate of climb aprox 300fpms you will be underground before the gear has time to retact!
BOTTOM LINE, GEAR DOWN LAND! GEAR UP GO!
This is why retacting the gear at the appropriate time durring T/O is critical. When you dont want to land anymore pull it up otherwise leave it down.
by the way to see how much runway it would use to reject at 50ft add the obastacle t/o to the obsatcle landing, 5000ft is plenty.
last note; most accidents in a twin are stalls/vmc associated with an engine fail or just pilot error in a good airplane. Would you rather VMC and die or overrun the runway and walk away from a totaled and insured airplane that isnt yours anyhow...
