acaTerry
SAPM
- Dec 4, 2001
I like your points, but there is one you miss, and it drives me crazy. I see it at DVT all the time by the academy aircraft and its only a matter of time...UndauntedFlyer said:Let's talk about retracting the landing gear after a normal takeoff.
They use the tower as a point to retract the gear (its 1/2 way down the runway). This is poor instruction. These instructors need to explain WHY they use the tower and then go on to explain that ALTITUDE GAINED AND SPEED are deciding factors as for when to retract gear for the decision to land or go.
I cannot believe how many times I see the Seminoles, after a go around, at 300 feet with gear DOWN until they pass the tower. Or follow through on a touch and go and bring the gear up at the tower when they are barely off the ground. The plane settles and nearly strikes the runway. I just love that diluted teaching!
