EMB170/190 Drivers
BrickTop
What is that god awful groan and vibration heard and felt when sitting in first class especially 1F. Its fairly consistent with higher airspeeds and usually diminishes during lower angles of attack. The ERJ145 has similar airframe vibrations during cruise but nothing like the 170. Sounds like N1 vibrations and or an access panel open causing rough airflow over the fuselage. Sounds like some impending failure. Spooky.
I don't fly it, but I feel it, and hear it to
It's the passengers "groaning" at the reality of paying a full-fair ticket to have to sit in an RJ from Milwaukee to LA.
The "shuddering" is from the terror at seeing both pilots still wearing braces
First I've heard of that one.
One thing I do know is that the bird shakes more than my epileptic dog when you grab a handfull of the ************************* stick (Spoilers)
Not that I've ever had to do such a thing. Wink, Wink, Nudge, Nudge
We have terrible door seal (weather striping around door not actually the seal) vibrations on some aircraft. Ive flown the 145 and this airplane and never had anything like it on the 145's. Funny thing is that the striping is so necessary that maintanance just cuts it off and that is th fix. The plane does have alot more air noises than other planes Ive flown.
like the guy above, it is the door seal. any dirt in the area where the seal inflates causes a small gap (not big enough to cause any press problems) and thus the sound.
I've found that once the aircraft accelerates past .75 it goes away. This would suggest an airflow situation where maybe some part of the door seal is into the airstream but over the years the EMB company reps. say its a tiny pinhole caused by dirt between the door seal frame and the inflatable seal.
the best solution is to have mx come out and put that solvent stuff they have and clean around the door seal and it goes away.
The ghosts of airline pilots Past, turning over in their graves as they see snot-nosed punks flying those planes for sh1t pay.
Hardy har har! You guys are hilarious.
I've never heard anything like that on the 190.
But it does shake like hell when you ask for full spoilers...turbulent air over the horizontal stab. Heavier the better...doesn't seem to shake as much then.
RJs have spoilers, slats, go faster than .75? What a crock of shee-it. Commuter airlines should be restricted to turboprops.
:p
This is not a door seal. I have heard poor door sealing this ia a low groan like a deep viration in the fuselage.
I know exactly what you're talking about and it's not a door seal. There is a distinct difference. I have over 2000 hours on the 170/175 and I've always heard this noise, but can never identify the source, nor can anybody else i've asked. It does not happen all the time, and yes my fellow crewmembers have noticed it as well.
:p
But it wasn't. Get over it. Do you constantly bitch over the things that you wish that were but are not? Say something constructive folks.
This seems doesn't make sense.
Don't we usually use lower angles of attack at HIGHER airspeeds?
SLower meaning near approach speeds. Lower angle of attack and slower speed meaning on approach vs initial decent at 320kts
Has anyone written Embraer. Somone should. To me it sounds pretty serious. Apparently not since none have fallen out of the sky yet.
Whats a "first class" first of all?
I've never heard that either, must be the wallet of the pilots screaming for more $$$$$. But we're fixing that on all the jetBlue E90's...
It sounds like the door seal vibration issue. It often sounds from the flightdeck like there's someone paying a horn in back of the plane, like a distant buzz/humm. The sound usually manifests itself at higher airspeeds, starting at 15,000 ft or so and slowly fading as you climb higher.
I don't believe its the actual internal pressure door seal, but rather the rubber shroud that is mounted over the top of the forward doors, over time the shroud wears and airflow may get between the rubber piece and the fuselage causing the vibration/humming noise. I've seen these removed from the aircraft on occaision, there is CDL relief for it. Occaisonally, a little fidgeting with the rudder trim will cause the airflow to change a bit, the seal will lay flat against the fuselage and the noise will go away. Its benign, however annoying.
I'm also wondering what kind of noise the wheel wells could make in flight, as they are partially open. If the brushes around the tires are getting ragged, or if say one of the mains retract and stops just shy of where it should... etc. etc. I'm sure some wierd air flow noises could emanate from there as well, if everything isn't just so.
I thinks that as lots more of these aircraft enter service in the US, the airlines will get all these bugs worked out and the aircraft will become a true regional workhorse.
Those were my thought exactly. Funny. I thought about the aerodynamic brushes on the wheel wells being a culprit. Either way its definitely bizarre. But its Brazilian what isn't.
Dude...you're good!
Thank you. But, I was merely mentioning the fact that as the 170/190 get more numerous in the fleets of regional airlines, that the nagging bugs that are inherent in any new type will get worked out and the aircraft will become the new standard for regional airlines, much like the 50 seat RJ is now.
...aaaand that was the problem...
It is the flap on top of the door not the seal. The door flap comes from the factory too long and vibrates against the fuselage. The maintenance solution is to cut the flap shorter.
