YeOldeProp
- Feb 12, 2002
Lots of good info on the subject...with the usual minor doses of dissention just to keep the thread hot. Gonna try and summarize the safest way to fill out the columns from the SWA app based on what the gang on line have said. Just looking at the military hours (AF Form 5/Flying History Report) and not extra civvie flying y'all have gotten over the years. And as Snoopy58 has rightly said in the past...folks on this site aren't on the HR or interview panels...so take this compilation with a grain of salt. If seriously worried...call the HR folks and get the real no-kidding answer (and share with the rest of us). Again, just trying to summarize.
Total Flying Hours:
All your PIC(A code) + SIC(A code) + IP/EP (combined) + Dual recv'd/student (summarized as everything in UPT up through your first MWS aircraft commander checkride--early for fast jet guys, later for heavies) + a .3 hour per total sortie (as in from the very beginning of your flying career) correction IAW the SWA request. Disregards any "other" time you've picked up over the years whether you were A-coded or not. Biggest hours number on the app, especially if you add in civvie flying hours.
Jet PIC: (fast jet guys please edit/correct as required)
All your PIC(A code) + SIC(if in a two-seater???) + IP/EP (combined) + a .3 hour per sortie since your aircraft commander upgrade (or initial MWS checkride?). Cargo/bomber guys probably follow the criteria in the below paragraph. Don't put your UPT solo time (again...the safest way to input to SWA). Still a debate about PIC when solo...
Turboprop PIC:
All your PIC(A code) + SIC(A code) + IP/EP (combined) (after your first MWS aircraft commander checkride) + a .3 hour per sortie (A code sorties only) correction. Probably a good idea to trim the total by 10% (per Ivauir's suggestion) to account for training time, times when you weren't the A-code but flew (dual crew deployment to overseas, etc). If you need the hours...don't take the 10% off the top.
Total Turboprop/Jet hours:
Same criteria as Total Flying Hours above.
Turboprop/Jet Time (military transport/cargo) PIC and SIC blocks:
Use the hours criteria from PIC and all the other is SIC. Info is just split out to make it easier to see. Again, no other time involved at all. Add civvie time as your log books are written.
Jet Fighter/Bomber Time: Fast jet guys show what they've done, and Bomber guys probably need to follow the same as above.
Sorry if this rambles, but just wanted to try and get one combined "suggestion" of what to put down to satisfy the SWA People department, and make the day of the logbook checker that much easier when you get there. So...let the shooting begin...I'm sure this thing has a fair share of targets in it and am waiting for them to be pointed out...
Off to get a cold one after all this typing and brain confusement. Good luck all...
Total Flying Hours:
Turboprop PIC:
