True. A certificate holder can obtain authorization for pilots to perform certain items of preventative maintenance. It does not need to obtain an authorization to do things like add oil, which is NOT an item of maintenance preventative or otherwise.
Again, you are wrong, which is consistant...as you've been wrong about everything you've stated from the outset. Adding oil may be complex in nature, and for a certificate holder, may require an authorization and documentation of training. The Piaggio Avanti, for example, requires that one climb onto the wing, remove fifteen self-locking internally threaded (and expensive) screws, remove a panel, and remove a cannon plug before unlocking and removing the dipstick to check the oil...which must be done within 10 minutes of engine shutdown. Not quite the same as dropping a quart in your 172 is it, pal? Add too much, blow a seal, lose the engine...not good. If operated by a certificate holder, adding oil requires FAA approval, an approved training program, certification of completion of that training program, and pilot approval to check or service the oil.
Numerous aircraft require more than flipping a latch and unscrewing a dipstick to check fluids or service them...but your experience with your examiner in your 172, over which you won't be losing any sleep, has made you an expert on that subject, so we needn't say more. Need we?
etc etc.
Irrelevent, as is the rest of your rambling about magnafluxing and so on. The question is the legality, not whether I understand the proper way to do it or have the tools.
Hardly irrelevant, as the question of legality with respect to your ability to perform any given operation demands that you meet all the requirements of the operation. If changing a tire requires that the wheel halves and bolts be magnafluxed, then it must be done, and if you're not qualified to do it, then you can't do it, and you can't change that wheel out. It's very relevant, indeed. You need to know this from reading the current publications for that wheel assembly...all of them. This includes wheel manufacturer, tire manufacturer, brake manufacturer, and airframe manufacturer, as well as applicable airworthiness directives, and in most cases, research in the aircraft logs to determine cycles, previous work and compliance, etc. All of this before you can touch the part. Very relevant.
W(h)eather you have the calibrated tools called for in the approved documents, know how to use them, have the training and experience to perform the work to industry standard, and the ability to execute all the necessary documentation, is extremely relevant, as it's the crux of the legality of the matter. But you knew that too, didn't you, expert?
Sure. It requires a maintenance entry under 121, because that's part of our approved maintenance program. It requires a maintenance entry if you have to remove a panel or cowl. Otherwise, it's not. It's routine servicing, no different then adding fuel.
In a piston engine, true. Not in in a turbine engine.
49-31-02
AD 49-31-02 involves installation of a placard. It requires one-time compliance, in installing the placard. It does NOT require compliance or a log entry during fueling, as compliance is satisfied by installing the placard. What AD's have you located specifically regarding fueling the airplane? I'll give you one. AD 60-13-03 requires compliance at each fueling in certain Lockheed aircraft...and if compliance is necessary, a maintenance entry is necessary. Fly anything with a required fuel additive? Is it mandated by an AD? Even if it isn't, is it blended to spec by weight or percentage, and have you made that determination? Does an AD require the use of certain fuel tank treatments in your aircraft, and if they've been done, have you checked to determine the legality of adding fuel and by what percentage you can do the mix? You knew about that, didn't you? If you didn't and screwed up, you were unable to perform proper servicing of the aircraft, allowed in theory by Appendix A or any other location...and it needed to be done by a certificated mechanic. But you knew that too, right?
Flown a Mooney? Know about AD 2004-25-04 and compliance with each fueling, depending on the specifics spelled out in the AD? Depending on your AMOC, a log entry may be required every time you fuel or preflight...and that for your "routine servicing." Go figure.
But this thread isn't about fueling or hydraulic fluid, though you've certainly attempted to make it so. It's about Nitrogen. Nobody's addressed this regulation so far, but 14 CFR 25.733(e) specifically requires nitrogen, as a function of certification (and subsequent airworthiness for aircraft certificated under Part 25) in large aircraft over 75,000 lbs:
(e) For an airplane with a maximum certificated takeoff weight of more than 75,000 pounds, tires mounted on braked wheels must be inflated with dry nitrogen or other gases shown to be inert so that the gas mixture in the tire does not contain oxygen in excess of 5 percent by volume, unless it can be shown that the tire liner material will not produce a volatile gas when heated or that means are provided to prevent tire temperatures from reaching unsafe levels.
Moving right along...
Anther one I pulled out of "thin air" to support a "100 % incorrect point"
Your point was that...
Plenty of "certified mechanics" have killed themselves by attaching unregulated 3000 psi nitrogen bottles to aircraft wheel assemblies.
To which I correctly replied that this is an extremely rare occurence.
Of course, the article that made you an authority and expert on the subject claims that...
Thousands of airplane tires are inflated during routine maintenance each day around the world. On occasion, a mechanic or other ground service employee has been severely or fatally injured in an explosion caused by use of unregulated pressure from an air or nitrogen tank. The latest reported incident occurred in 1998 when a mechanic was inflating a nose wheel/tire assembly on a 737 airplane. A total of five similar incidents have been reported as the cause of severe injury or death to maintenance personnel
According to you, plenty of certificated mechanics die from this action...your point is irelevant because it doesn't apply to anything under discussion...nevertheless, you introduced it...plenty of mechanics die doing foolish things during routine servicing. According to the evidence you introduced, thousands of tires are serviced daily. Being a multiple of a thousand, let's stick with the minimum number of two thousand, and multiply that by 365, as these thousands are being serviced daily. This gives us a minimum of seven hundred thirty thousand tires serviced annually, times eight years, as the reported 737 tire explosion occured in 1998...in the intervening years, eight in total, we can see a minimum of fifty eight million, four hundred thousand tire inflations by maintenance personnel. Of these, five have been reported to have been done directly from the bottle, for a microscopic rate that apparently establishes your definition of "plenty."
Your definitions are clearly skewed, as are your examples to support incorrect points, your incorrect use of inappropriate and inapplicable airworthiness directives that are off-topic and irrelevant (did you read them?). The one link you did provide includes one paragraph of use, which does apply to the topic at hand, as follows:
Inflating wheel/tire assemblies only with nitrogen.
Tires must be initially inflated only with nitrogen. However, air can be used to top off a low-pressure tire if the airplane is in a location where nitrogen is not readily available, provided that the oxygen content does not exceed 5 percent by volume. Optional procedures for ensuring that the oxygen content in the tire will not exceed 5 percent are typically found in chapter 12 of the AMM. These procedures include a table that lists the maximum refill pressure versus the initial tire inflation pressure. The sum of all air pressures added to a given tire cannot exceed the pressure shown in the table for the corresponding initial inflation pressure.
Thanks for playing.
