Delta: These are the "RAISED Fares"?????
I suspect some of it is just a marketing ploy. If you look at the restrictions, it is only for Tuesday, Wednesday, and Saturdays. I agree that it doesn't make sense as a lot of these flights are full.
In june, Cak to LAS through ATL price was 89.00 each way. SWA was 199.00 each way from CLE, and this was direct.
The 757's and 767's probably have a lower CASM than Airtran's airplanes due to the larger number of seats, but they have trouble nowadays generating a larger RASM domestically. Thus, the general shift over the last few years of the 757/767 from domestic flying to international. I believe Delta's ratio for ASM now is pretty close to 50/50 for domestic vs international (correct if I am wrong GL). Three years ago the ratio was closer to 30/70 favoring domestic.
RASM is actually over 50/50 in favor of international.
Delta's RASM is actually above the industry average now. In the past it had trailed by as much as 15%.
Wow, just looked up AirTran's numbers. Thanks to saving ~$300 an hour on crew costs, they are very competitive. I'm guessing longevity is the biggest difference.
717: (unable to locate)
A320: 6.1
737-700/LR (AAI): 5.0
737-800(DAL): 5.6
757-200 (DAL): 5.4
757-200 (NWA): 6.0
757-300 (NWA): 4.2
767-300: 5.6
A330: 4.3
777: 5.9
* Delta's new seats that put 10 more passengers on board will lower their 737-800 CASM by around 7%, so an apples to apples comparison of Delta v/s AAI on 737's would be 5.2 to 5.0 CASM.
** Delta will get slaughtered on any markets where they run CRJ200's (13.4) or DC9-40/50's (9.5 to 8.8) head to head with AirTran. You can't make money when your costs are 75% to (gulp) 268% higher than your competition's.
