FL990
- Oct 30, 2004
Do you have a reference or a site where I can see this data for myself...because this does not sound correct at all. When I went on Delta Net and did some searching for numbers, I came up with between 25% -30% of the total number of flights in the delta system as being operated by ASA/CMR. However, this should by no means be in direct proportion to the total number of of block hours which is what the TA refers too (or at least that is what I have been told by ALPA MEC members that the TA refers too). The average Delta flight as i have said before is substantially longer than that of ASA/CMR.~~~^~~~ said:The RJDC has run the numbers and I imagine Surplus has seen that data. He is correct, that currently ASA and Comair exceed the 25% number. I think the current number is 29%+ ( based on ASA management sources ). Whether or not this "floor" is a help, or a hinderance, has yet to be seen.
Please don't take this the wrong way...I'm not calling you a liar...I would just like to know where I can find the DATA that you are refering to. Where is it posted?
