Delta MD80 Slides off Taxiway in IND
DenverCrashpad
Total Time
5000
http://www.wthr.com/Global/story.asp?S=9535716&nav=menu188_2
Indianapolis- The weather may have caused a passenger plane to slide off the taxiway at the Indianapolis International airport just after midnight.
The Delta flight had 117 passengers on board.
It was headed to Milwaukee from Chicago, but by the time the plane got to Milwaukee that airport was closed. The plane was then diverted to Indianapolis.
Passengers say the slide-off happened just after landing as the plane was slowly taxiing in.
"We came in and slid on the runway and ended up in a little bit of grass. So they sent seven busses for us," passenger Donna Searles said.
"Came in for our landing landed the plane we were turning to get onto the taxiway and the plane slid into some black ice right into the grass, " passenger Nick Gardner said.
There were no injuries on board and the plane was not damaged.
Scope out RJ's
Total Time
20,000
Ok, cue tanker clown in
3................2.....................1.................
Tanker Clown
KC-10 IP
Total Time
1700+
What is it with you guys? Looks like this is just becoming an annual event. He's a news flash for 2009..."Delta aircraft taxis of taxiway in XXX (insert location here"
Delta should just buy a bus fleet at station them at all their locations. It would probably cut down on the costs of hiring out the recovery of pax stranded in the grass at assorted airports.
When are you guys going to start taking safety seriously?
poppi
Total Time
14000
Tanker Clown
When will you ever get on with an airline. Always trying to get in but will never make it.
landlover
Total Time
5000+
Tanker clown with your infinite wisdom acquired in all those hours you have flown, 1750. you are a seasoned veteran sir.
Tanker Clown
KC-10 IP
Total Time
1700+
You can say whatever you want about my flight time, but at least i've never left a prepared surface. Safety is paramount for me. Maybe instead of giving me a hard time, you should focus on doing things right.
75M
Total Time
9000+
Commuted home last night and EVERYTHING was like a skating rink. I had to stop twice on the way home to scrape off the windshield. It was icy, but if they were out of better options and everybody walked away, I say "good for them".
SiuDude
Internet tough guy
Total Time
Why
Actually, the flight first diverted to ORD. After getting fuel, it took off for MKE just as the weather was worsening, and then diverted to IND.
Noserider76
Teahupoo
Total Time
150+
If that's the case, the Delta crew should have picked a better divert location.
Everytime I see you've posted I see my tax dollars going down the drain. This much time on your hands during business hours means you're completely expendable to any unit you belong to. Nice career you've had.
Tanker Clown
KC-10 IP
Total Time
1700+
Noserider, less time worrying about old Tanker Clown...more time worrying about staying on paved surfaces.
Tanker Clown
KC-10 IP
Total Time
1700+
Banked? No. I did an internship at the Pentagon and was a Senator's aid for a while though. I was already a pilot then.
Papa Woody
Total Time
8,000
That's what happens when you let 15,000-hour pilots with only 15 yrs. seniority upgrade to captain.
There should be a 20,000 hr/20 yr seniority rule at Delta.
Allegiant has a better MD-80-series safety record, and has quick upgrades, so it's probably something intrinsic to Delta.....there should be an immediate, in-depth investigation.
LandGreen
Total Time
where?
What is Allegiant? Never heard of it...
SiuDude
Internet tough guy
Total Time
Why
You held a position which you don't know how to spell?
Hmmmm.
glasspilot1
Total Time
14000
Anybody know what the braking reports were in Indy at the time of their landing?
I know in the past when I had landed in icy conditions the rule is to not turn off the center line until you're slowed to a crawl. If you have to pass up a taxiway and take the next one, do it. Even if it means someone behind you going around, too bad.
Sinca3
Total Time
unknwn
What...Allegiant has like 1 MD80. If they were to crunch it they would be SOL.
landlover
Total Time
5000+
i doubt tanker clown even holds a private pilot certificate.
