Delay Gear Extension in icing?
We drag the brakes a bit on before takeoff to warm them up, then leave them down a little longer to get the slush off. On landing, same procedure as usual to put them down, but we will turn the antiskid off and pump the brakes a few times to brake any ice that could have formed on the brakes.
Do what you get paid to do, follow the SOP procedures.
There ya have it. To do anything else is to operate outside the safety of the SOP. Our SOP has the gear dropping just prior or at the final appch fix - how much longer would your Capt suggest to wait to drop the gear? This sounds like an accident/incident waiting to happen.
One thing to remember....If you do what your SOP says you will be safe. Be not afraid to tell the Capt, "Nope, sorry guy - I'm not doing that. We can talk to the CP later if you wish - but I'm not operating outside the manual."
Good luck!!
Baja.
Good luck!!
Baja.
Sounds like good advice to me. Last thing I would want is to do a carpet dance in front of the CP because I went outside SOP and possibly forgetting to put the spark arresters down because I wanted to delay it due to icing.That would be 15 minutes of fame I wouldn't want.
Remember Hibbing, MN and the Express One JetStream-31 fatal accident. Express One pilots had developed an unauthroized procedure to fly through icing, it was called the slam dunk. Fly over the IAF at about 6.000' over the published altitude, and then flt idle descent in an unstablized apporach to cross the FAF on altitude. Icing was never problem, but slamming the airplane into the ground at 2,500/min descent was the result. 18 dead, 2 crew 16 pax
The pilots of Express I did not invent the "slam dunk" nor did the maneuver die with those unfortunate 18 souls. The most unfortunate thing is that these types of "creative" procedures will always exist so long as pilots are willing to operate aircraft into weather they are not intended to operate in.
So you are saying JS couldn’t handle the icing conditions? From former JS pilots I have been told that the JS was OK in icing, it handled it like it was supposed to. The DO, CP and POI were relived of their duties because of this accident the NTSB said these individuals were aware of this unauthorized procedures, but allowed it to continue. Not to mention that he Captain a former Nuc Power Plant Officer had flunked checkrides 6, 15, and 24 months prior to the accident.
What do you guys think?
I think a 10 pound rooster is a lot of Cok!
I've heard the same thing about extending the gear, but I have never seen anything written.
Leaving gear extended on T/O is on the CRJ MEL... I know I've done it but can't remember what the 'fault' requiring the delayed retraction. It's been 1.5 years since I flew that thing. Can anyone tell me if I am mixing this and something else up?
I flew with a guy who insists that you should wait to extend the landing gear while in icing conditions. He said the brakes could not work if you leave the gear down in icing. Being a former frieght dog I was surprised I had never heard of this. What say you guys?
When the wheels touchdown, spin up and you apply brakes, do you have any idea how much heat is generated? It sounds like a good way to forget to put the gear down though.
I fly with many former J-ball pilots and to the last man they say it performed OK in light icing. More than that and you had a problem.
I'm not sure what any of this has to do with the topic. Clearly, you just have an axe to grind.
That MEL is for the gear bay overheat sensor(s) being inoperative.
