CRJs limited to 250 KIAS?
Sgt. Hartman
What do we get for $10?
In the past couple of weeks I have heard more than one CRJ tell ATC that they are limited to 250 knots for the entire flight. Why is this? I hope that the gear wasn't stuck down.
Reduce to Payroll Power!!!
it's because pinnacle pilots kept exceeding the 250 knot limit below 10,000. it was getting to be such an epidemic that they decided to limit all their crjs to 250 knots all the time.
if you aren't smarter than the rules, than the rules will have to be changed.
I'm sorry, I couldn't find smooth air anywhere! Back to turbulence penetration speed we go. Wouldn't want to bend the airframe in case we hit some extreme turbulence in this severe clear weather. ;)
As Eddie Murphy said in 48hrs... Ha Ha.......Ha.
Tool
Uhhh...isn't that speed 280 KIAS? ;)
ha ha ha. the real reason is that we have had quite a few a/c that have a CDL limiting them to 250 kias. this CDL item has to be repaired in 7 days.
I can't remember!
Just exactly was that CDL. I have been out of the lime light for a little over a year and can't remember a 250 KIAS CDL. I am just curious, not implying you are wrong. Thanks in advance.:)
I had something similar to this last week. A deferrel of part of the BTMS required the gear to remain down for 10 minutes which limited us to 250 kts.
Anything that has anything to do with the gear system. Landing gear doors, door brushes, as well as anything that would keep the gear fixed down.
I've flown several of these types of deferrals over the last few months. Things have a tendency of not getting fixed around here lately, mostly due to lack of parts.
The aircraft will often have the part in question replaced from a perfectly good working aircraft, then THAT aircraft will be DMI'd for 7 days. Seen it a couple times now, it buys the company time...
p.s. That's pretty funny Rook... brought back memories - haven't seen that movie in a while. :)
missing gear doors. i think that it's CDL 32-12. this CDL takes a weight hit depending on which flaps setting you use. it also takes a 0.7% burn penalty.
I heard that the restriction in speed is due to an AD put out by the Feds restricting speed to 230kts because the low time pilots flying them are having a hard time keeping ahead of the plane. The AD does NOT apply to pilots that have attended Riddle's high speed aerodynamics course. As they have shown on paper that they can handle the speed of the CRJ.
