CRJ down in MO!
manfred33 said:
Super_Cub, you're a moron. Never assume you know everything, because ultimately, you will meet someone who knows more than you. In your case, this means everyone. How often do you think that FAA database is updated? The guy was typed in the CRJ otherwise he would not have been a capt., nor was he a street captain. Secondly, he had more flight time and air carrier experience than you in your stinkin' cubs. You've got a lotta nerve posting the things that you do about people and situations you know absolutely ZERO about. Your posts don't make you sound anymore intelligent than the media that reports on aircraft accidents. You should really think long and hard before you click that "submit post" button; in other words, don't follow your instincts.
Actually the FAA web site is updated regularly... My guess is that the Captain was typed within the last 90 days or so since he certificate information on the site doesn't reflect the Type Rating (B-1900 is the only Type shown at this time), if he was typed earlier it would have been up on the web site already...
To be honest, when I looked up the crews info, that was the same thing that went through my mind... From the information on the web site it looked as though both pilots may have been relatively inexperienced in their psoitions...
Again, only going by the information available on the FAA web site. I didn't know either of the two crew members...
May God rest their souls...
ATL2CDG said:
Why not? I'd rather it be an uncontrollable failure of systems from which the guys couldn't recover (viz not their fault) than one of them making a stupid mistake like going to flight idle and pulling straight back on the yoke or purposely cutting the fuel flow then ignoring the EICAS as they tumble towards the earth.
Let's just wait for the NTSB report, or at least info from the black box, before we start wringing our hands and saying "I hope this reporting isn't accurate"; once we have some actual facts (rather than speculation), then we can p!ss in our pants.
Because genius, an "aerodynamic stall" at an aircraft's max service ceiling (41,000') seems to point in a certain direction. That's why I hope the reporting isn't accurate...the same reason as you. No hand-wringing here.
CA1900 said:
Heh, if you find a news organization that operates that way, please let me know and I'll tune in!
Fox News???
J/K!
Well, the FAAs image has never been that of speed, so thinking that that database is not updated regularly was not a long shot. I do stand corrected though.
Well, considering they were trying to put it down at the airport located 2 miles away, I think that they did a pretty good job not killing anyone else in the process. Let me know how you do next time you have a dual engine failure in a 30,000lb+ jet.
Corona said:
Wow, the crew put the ship down right where it was safest, in the middle of a densely populated area. Top-notch pros to the end.
Ok, some of you were justifiably pi$$ed about this post. My words were extremely poorly chosen-I can see how it might be read two ways. My guess, as some others have posted, is the airplane had a dual engine failure, and had the difficult job of putting the ship down in a populated area. They were obviously top-notch professionals to keep their bird from hurting anyone on the ground.
My original post was not intended to be sarcastic. I would never make such a comment about a trajedy like this. I have nothing but respect for this crew, and hope for the best for their families.
ECUs and Control Amplifiers are located in the Aft Equipment Bay.
DCUs are located in the cockpit.
There is no FADEC on this a/c.
A "stall", aerodynamic or otherwise (g), would activate Continuous Ignition before exceeding critical alpha.
For an estimated weight of 36000#, FL410 was well within the envelope of this a/c. I have personally hand flown 444F at FL410 M.71 MEM-PIT in 2001 with 20-23 pax at 2100 local. Climb performance may suck, but you most assuredly are not "on the ragged edge". I have hand flown with JM and SM to and from Mexico at FL390. Not an issue.
The FAA registry updates every business day at midnight--for those who have not opted out for privacy. I do not believe that you can "opt out, new info only"--so it is _reasonable_ to assume that certification happened withi the last 120 days.
The FO came from Gulfstream, so it is _reasonable_ that his CPL was from the last year. Of course I've been flying for 15 years and have a date of last August--because they were lost and reissued--so it might be nice not to carve up the professional reputations and experience of the crew.
If you want to speculate, why not just say that DW got hungry after eating all the pizza at the last pilot meeting and decided to gnaw through cabling in the AEB? Oh yeah, he can't fit in the hatch. My bad.
I forgot that it had no FADEC.
The media insinuated that the flight before the accident flight aborted due to a bleed leak warning. Is it possible that a catastrophic bleed leak during the accident flight resulted in malfunction of both ECUs? Just speculating here, but there are only a few situations that would impact both engines.
Corona- Whatever, man.
A loss of all engines in a Part 25 aircraft at night is about as bad as it gets. Let's refrain from making comments about experience until the facts are in!
From KOMU--the voice of the inbred Missouri Hill People, or something like that...
http://www.komu.com/crashfollow101504.htm
While investigators refuse to speculate about the cause of the wreck, a review of NTSB and FAA incident reports reveals planes like the one that crashed have had problems reported. One incident report quotes Pinnacle Air's Chief Pilot as saying this model of aircraft has continuous problems with its flaps locking in the downward position and refusing to return to the level position for regular flight. And in at least one other case, pilot error contributed to an engine failure that caused the plane to crash shortly after takeoff.
I've known Terry for years, and that does not sound like anything he would say, commit to writing, or even the way in which he speaks. I am really confused about the last sentence as well.
The only SDR's on this plane are when JM's FO broke the gear handle during IOE.
Thanks, thought the ECUs might be in the AEB.... Wasn't sure.
My point exactly.
Don't know Terry that well, but don't think he would have made a statement like that either. Once again, the media doing a wonderful job in reporting.
No kidding?
Agreed, sounds like someone made up a bogus quote, or they got that one from a 3rd party that decided to give them a completely false tidbit. I seriously doubt Terry would say such a thing.
Also, since this is getting a decent amount of press attention, we sould also be acreful what we speculate on this message board. If anyone else remembers, after the Colgan crash in Hyannis, a reporter from a Cape Cod newspaper came on here looking for pilot feedback on the crash. The last thing we want to do is to dishonor Jesse and Peter by giving theese rabid reporters nothing but wild speculation to feed thier appetite.....
Actually, the engines don't have ECU's. They have a FCU mounted on the engine that is nothing more than a hydro mechanical metering device that supplies fuel in response to thrust lever position. It also controls the position of the vairable geometry inlet guide vanes and stator vanes.
Connected to that is the N1 control amplifier which trims the fuel at higher power settings. Greater than 79% (N1 mode). (at lower power settings, the fuel is controlled strickly by the FCU's also known as N2 mode You can turn the amplifiers on and off with two switches in the CP. (Speed Switches).
This pertains to the 3B1 engines on our aircaft. Not sure what type they have at pinnacle.The APU does however have an ECU.
The DCU's don't control the engines at all. All they do is provide the infomration to the EICAS screens in digital or analog formats from diffrent aircaft systems.
Example :aircraft systems
IAPS, stall protection, GPWS, clocks and AHRS.
they process this information and display it on the EICAS, lamp driver units, the MDC (maintenace data computer) and FDR.
Actually they do. That's what controls the engines at high thrust settings, in conjunction with the FCUs. The DCUs, as you said, do not control in engine function at all, they just collect all the data and organize it to be displayed on EICAS.
efiscompmon.
inbred hill people?
cmon....where you from? ill bet theres alot of smack i can give you about that.....
anyway, im familiar with that exact location and its 3 houses down from my old chief pilot's current house.....
to land it where they did not hitting any house at all....means theyre either extremely lucky or extremely good. its more of a ditch they put it in. nice neighborhood....just a bad place for a plane. looks like the earlier eyewitness reports of fire before impact were unfounded. will be interesting to hear the problem that caused BOTH engines to fail.....
i will continue to pray for them.
I guess the two types of engines are diffrent then. The 3B1's don't have them.
The N1 amplifiers along with the FCU's control our engines. ECU's are not mentioned anywhere I can find. I even pulled out the book. LOL
Well, we also have 3B1s, sooooo either one of us is right or one of our manuals is wrong!! :confused: Our manual says that we have an ECU. Very doubtful that they made "special" 3B1s and even more doubtful that our company would pay extra money for "special" engines...:rolleyes:
-3A1 and -3B1 differences are limited to -3B1 "improvements in compressor and turbine construction which has resulted in a reducton in total fuel consumption and improvements in flat-rated power capability." (Bombardier PTM, 20-1)
From the Bombardier FCOM vol.1 (the big silver one from the manufacturer), p18-10-1
"When at high thrust settings, the engine is controlled by an electronic control unit (ECU) which works in tandemwith a fuel control unit (FCU). The ECU monitors sensors (T2C and P3, etc), sets up the appropriate fuel, acceleration and temperature schedules, and relays appropriate operating data to the flight crew through data concentrator units (DCU) to the flight compartment displays (EICAS)."
p18-10-6
"Speed control is as follows:
--At low thrust settings, the FCU meters fuel to the injectors to control N2 speed. In N2 mode, matched movements of the thrust leversproduces matched N2 speeds but N1 speeds and thrust may be mismatched between engines. A mechanical thrust lever setting and N2 speed schedule is contained in the fuel control unit.
--At take-off, climb, and cruise power settingsthe engine is N1 speed controlled. In N1 mode, the FCU responds to N1 speed references. Matched movements of the thrust levers produces matched N1 speed and nearly matched thrust between engines. An electrical thrust lever setting and N1 speed schedule is contained in the fuel control unit and controlled by the ECU. Switch over from N2 to N1 control can occur at speeds above 79% N1 by switching N1 control on.
--If N1 mode is selected off, the engine speed control reverts to N2 mode (mechanical)."
See? Everyone is right! Now let's go have a beer in memory of our friends.
Possible that they had the APU shut down with the fuel flow continuing and filling the aft equipment bay with fuel and fumes? If that happened (has happened before several times) and there was an ignition source that could explain the witness reports of fire and a dual engine failure...
No matter the cause, God bless the crew and their loved ones...
atrdriver
I really don't know WHY it matters.. but Jesse upgraded about a month ago, although he had 18 months in the right seat and previous 121 PIC experience. The FO had a few months in the right seat.
Regardless of how much time someone has in a specific seat, they still had time in the aircraft. This could of happened to someone with 5,000 in the left AND right seat. Time is relative, they did the best they could have done with what they had to work with and I hope no one will aruge that point.
You are absolutely right. It just makes matters worse to sit here and spectulate about what happened. It's terrible not knowing what happened, and until we do, we just have to agree that it is a terrible loss, especially to those of us that knew and flew with these two great guys. I for one am going to have a beer for Jesse and reminisce of the short time I knew him, as well as for Peter.
falcon20driver said:
why new pilots
Cause they were probably on reserve. Looks like it was a late night mx repo flight. Only reserve pilots normally would get that kind of flight assignment. Most folks upgrade as soon as they can for the pay bumb and as such are junior on the airplane and in the seat, so therefore are usually on reserve.
God bless them and their families, good people do not deserve to be taken from us.
This really sadens me.
I was just in Memphis a few months ago for the funeral of a friend of mine, a Pinnacle pilot. A bunch of you showed up at her funeral which showed a lot of class. You guys/gals are number one in my book.
My condolences to the crew's family and friends.
True, true, Colleen was a class act and gone way too soon. Only 6 months after her wedding, too. She was a former student of mine and a gift to the world.
Godspeed to the crew and my condolences to the family and friends, as well as the entire Pinnacle family.
LTG
jws717 said:
actualy a crj is a small jet according to the AIM, read the wake turbulence section. It refers to aircraft up to and including the 757 as a light jet.
This is incorrect! The AIM refers to aircraft more than 41,000lbs. MAGTOW and up to 255,000lbs. as large for wake turbulence separation minima. Small is 41,000lbs. or less. The CRJ is well over 41,000lbs. MAGTOW. Some 757s are true Heavies now too.
also.. A large aircraft is one that has a MAGTOW over 12,500lbs.
LTG
What happened to your friend Colleen?
I will do the same as soon as I get off reserve. Jesse was a competent, skilled pilot and a good man. Godspeed Brotha! Rest in Peace.
Although I never knew Peter my heart goes out to his friends and family and I will have a beer for him as well.
