Colgan 3407 Update
The concepts are basic but perhaps the techniques taught and practiced are not the safest options.
The altitude standards for recovering from a stall for an ATP certificate are +/- 100'. The only reason I see to not lose more than 100' if you were to stall an aircraft by mistake in an operational setting (not training) is if you were 100' from the ground, a situation that is possible, though only happens typically twice per flight very briefly. Conversely, there will never be terrain above you so why does it matter if you recover within 100' above you stalled altitude.
What if we trained to lose 500' in a stall and climb to 1000' above the initial altitude? Seems like this is a more likely scenario outside of the training environment. We could still practice the old way (flying right at Critical AoA when we know the stall is coming), but we would be taught that it is acceptable to lose altitude when lowering the AoA. This maneuver requires much less precision and, frankly, much less skill, but a safe outcome would still be assured, maybe more so.
Thoughts...
I concur with your thoughts... sometimes the forest is lost through the trees.
Given that, I'm honestly blown away at the cause of this accident. I had the false assumption that by the time two pilots reach a 121 airline something as simple as basic airspeed awareness is akin to second nature. :angryfire
This aircraft was not on fire, pieces of it hadn't been shot off, there was no particular terrain threat, no terrorists in the cabin attempting to gain access... in short, there were no extenuating circumstances that would warrant sufficient distraction to allow this condition to develop. THEN, regardless of how they arrived in an approach to stall condition, I'm again left speechless that the basic increase power, relax back pressure was substituted with a horrendous +30 pitch change as the stick shaker is activating. All I can say is, "WOW!"... and NOT a good wow. :mad:
My reaction to the cause of this accident may come across as harsh, but I EXPECT MORE of the pilots flying my loved ones. Many accidents that I read about leave me with the feeling that "there but the grace of God go I"... but this accident does not. I think it best that I conclude my remarks at this point. Thanks for the info....
BBB
I agree 100%. What happened is sad.... for sure. But they royally screwed up. Which resulted in killing people. What a disgrace. They are 121 AIRLINE PILOTS. act like it and fly like it. period.
You guys keep talking about pushing or pulling... How about what ever it take to hold the desired attitude for recovery!
That's what should happen. Problem is, the way many 121 carriers train, the "muscle memory" that gets associated with recoveries from approach to stall is to pull. And not many 121 programs seem to a) include full stalls, or b) approaches to stalls with the autopilot flying all the way to stick shaker.
Many 121 carriers don't include full stalls because your a commerical pilot and either with or without an autopilot you shouldn't allow yourself to even get to a full stall.
It sounds like a classic case of stall, spin, crash & burn. Normally at this point we'd be discussing a student\private pilot turning base to final or t/o with a high density altitude. The fact we are discussing two ATPs in a commercial airliner flying a relatively routine ILS is very, very disturbing. I'm with BBB on this one. I hope my perception of what happened is wrong, but wow......
And, yes, it COULD happen to any one of us given the right set of circumstances. We have sterile cokpit for a reason and I'm as guilty as anybody else, but the more experience I get the more I'm inclined to respect sterile cockpit. It's not the first disctraction that gets you nor maybe even the second one. But, at what point do the distractions rise to a level that they do make a difference? This crew may have found out the hard way.
While I agree with most of your thoughts, I disagree with your sterile cockpit assumption. Sterile cockpit doesn't just mean you don't talk at all unless its checklist related. It means you talk about anything that deals with the flight.
I think the distraction for them was the Ice that had built up. Remember the old saying, "As workload increases, Capacity decreases."
So is that wrong to discuss the ice on the plane? You can have a sterile cockpit and have both pilots fixated on the samething.
None of us are sure what happened, but listening to ATC Tapes and the FO's quick read backs (sometimes she didn't even read back the total clearences, only call sign) to me seems there was a bunch of work going on in the cockpit.
I seem to remember something on the initial release of the FDR data that the flaps were selected to 15(?), moved to 10, then reversed direction to flaps up. If this did occur, it could have been the final straw that caused the accident. The stick shaker/pusher is dependant on flap position and even though they were given a shaker and could have powered out of it, as the flaps retracted they would have been way below stall speed for their given flaps. Powering out in this senario would not be an option.
Is there still any validity to the theory that while the airplane was slowing with the autopilot on, it was constantly trimming for nose up, and once the stick-shaker happened with full-power application: that is what attributed to the 30+ deg. nose up attitude?
I agree, but if that was true we wouldn't have unusual attitude training either.
Also, it is sounding like they had a stall warning and then with poor recovery techinque, actually stalled the airplane.
The one thing that is suspicious in this investigation is the absence of any information related to power or thrust lever position.
This sounds like it has a lot less to do with proper stall recovery and more to do with a total loss off situational awareness (airspeed/power). The auto pilot kicked off, the nose dropped catching the PF off guard, resulting in the 25lb reflex pull on the control column. I bet that the pull on the control column came well before the application of full power.
I hope I am wrong, but I think we are going to find out there was more being discussed in the cockpit than icing.
I didn't see this anywhere. Was the autopilot on and armed for approach? Are they looking into false capture off of the course?
I agree. My sterile cockpit comments were an afterthought and not really a comment about this particular crew. However, if the accident was caused by a loss of SA regarding airspeed then any and all distractions were a factor, legitimate conversation or otherwise.
More true words have rarely been spoken. The trust the public places in us is sacred and this accident (like all accidents) is a stark reminder of that one basic fact.
It will be very interesting to see what is on the CVR. You know, it really could happen to any of us, really. Everyone has had a moment where they got fixated on one element of the flight and missed a radio call or forgot that they had already completed a checklist. That is why there are two pilots up there after all. I have a hunch that this is an accident that will be studied in CRM courses for years to come.
As far as turning off the auto throttles, I have no problem with that. You are required to maintain proficiency in all levels of automation. There is only one way to do that. Whats next? Can't disengage the auto pilot because it increases the work load?
But yeah, you have to watch it more carefully. I guess my CRJ is completely unsafe because it has no auto throttles.
The CRJ isn't unsafe at all. There are no auto-throttles so the descent is made the same way every single time. When you click the AT off sometimes and leave it on other times you are asking for trouble. One distraction, and airspeed will bleed off when the aircraft levels automatically.
I agree automation should be shut off from time-to-time but not in normal descents from the flight levels with the AP engaged. There are too many distractions and no upside. I regularly turn off all the automation and hand fly for proficiency but I pick my spots. Usually nice days when few distractions are expected in the descent all the way to landing. It's not in the weather during the descent phase when checklists and ATC instructions could cause a distraction.
Not sure if it has been talked about in other threads but what about recommendations of shadowing the controls even with AP on at low / approach altitudes. Personally I believe that the flying pilot must have the hands on the controls from 5,000 AFE down. There are many reasons for this. It can also be a way for a distracted pilot to get clues that something is going on with the plane that is out of the norm. Controls that start bucking or moving further than usual might cue you in to "hey pay attention to me!"
Not sure at all if that played into this accident but it is something I am concerned about as I fly and ride in jumpseats. I believe a lot of pilots have too much faith in the AP at low altitude. Just my opinion.
For years the FAA has had a "one size fits all" stall recovery training program. Push the thrust levers up and pull back on the yoke to minimize altitude loss. About 5 years ago the FAA put together and industry working group to rewrite FAR 121 sub parts N and O. These are your current training regulations. Shortly after Pinnacle 3701 the group began looking at what that crew did when they got stick shaker. The set full thrust and tried to maintain altitude. It didn't work and they realized that maybe they should get away from the "one size fits all" stall recovery training and began working on new regulations. On January 12, 2009 the FAA introduced a notice of proposed rule making with the new regulations. Take a look at the requirements starting on page 1360 http://edocket.access.gpo.gov/2009/pdf/E8-29584.pdf
The crew wasn't fighting. They were chit chatting about unions, contracts, pay rates and management like we all do. They got slow enough to get the stick pusher. The pounds of force pulled on the yoke is important because when the pusher released that's the force pulling on the yoke and hence the rapid 30 degree pitch up. They shoved the power up and pulled back on the yoke just like they were taught.
One size doesn't fit all.
Lol. I've tried shadowing the controls before. The sidestick and thrust levers never move. I learned shadowing them is a waste of time.
....albeit lowest-bidder ones!
I'm sorry, remind me. Exactly what does pay have to do with anything? I must have missed that part during flight training.
Yeah let's smear some dead pilots who left families behind on a public forum. You're my hero.
BBB
Which cause is that? Because all I've seen is speculation, and enough jumping to conclusions to get it in the Olympics. Or are you talking about the cause that will be determined at a future time?
Oh, and no matter how much this crew may or may not have screwed up when the final finding comes out, to think that you're above repeating anyone's mistake is a dangerous attitude. We protect ourselved from repeating those mistakes by studying the facts, and putting ourselved in their shoes, not by wild speculation and criticism based on early reports.
I'll remind you. The more qualified pilots apply to the higher paying airlines. The one's left over work at the lower paying airlines. The hiring standards at Colgan were practically non-existent at Colgan a few years ago. There are innocent people dead because of these pilots' mistake. I would not call it smearing, but just because the pilots are dead does not mean they didn't make a mistake. You guys can blame it on the training all you want, but if what the NTSB is saying is true, then this was just horrendous airmanship. These pilots should not have been flying this aircraft to begin with. There are experienced pilots out of work with 1000's of hours that would have no problem flying a Q400 if it paid a decent wage. Unfortunately it doesn't so you are left with some less experienced pilots to fill the void. You should not be building your experience as a 121 captain with an inexperienced pilot in the left seat. The system is broken. There have been a few accidents in the last couple of years at the regionals that could have and should have been avoided. We are very fortunate that there have been as few accidents as there have been with the regionals lack of hiring standards. Instead of raising pay, they lower requirements.
And there have been a lot of accidents at majors over the past few decades that could have and should have been avoided... Plenty of high-time, high-dollar pilots have dug smoking holes with their mistakes.
Well on that dumbass thought, how about one of the highest paid regionals and LEX? That crew dropped the ball pretty bad too!
So your money theory is screwed!
The possibility exists that the crew could have mistaken the situation for tailplane icing? In this case, then the aft column movement would have been appropriate..remember while the NTSB, and all the rest of the "hindsight committees" including ourselves on this forum have many hours days weeks to speculate and pour over data, the crew had mere seconds to react to a situation..
Airspeed, Power Settings, Attitude, Bank Angle, Aircraft Configuration, Weather Conditions
eP.
Which is a problem with the airbus design. No tactile feedback for what the autopilot/autothrottles are doing with YOUR aircraft. Usually, not a problem. Sometimes, a big problem.
Our SOP says that the PF must have his hands/feet in a position to immediately assume control at "lower altitudes" which is defined as anytime the flaps are out.
Not sure if this has any relevance to this accident but thought I'd take a poke at Airbus, it is always a good time for that.
Felt the same way before I started flying them..actually makes you more aware of pitch attitude thrust speed because one is forced to monitor the FMA more closely
had a bus captain tell me the other day, "don't ever trust 2 check airmen flying together. they blew through the final on a visual because the PF went down in the box as did the PM while they got a sidestep...
the public puts a sacred trust in us
just ask bernie madoffs' clients.. you're not alone
