The Prussian
Stecknadelkopf
- Oct 24, 2005
I'm no where near being able to remotely call myself an aerospace engineer.........but here's my 2 cents...a common everyday stall is the norm
(therefore that's what you try to protect against, you can overpower a stick pusher). A tailplane only stall is a function of the a/c being redesigned by mother nature due to ice.... I wouldn't know how you could mechanically differentiate or detect between the two....
(and would it be cost effective for something so rare? I'm not being insensitive to the price of a human life, just saying that flight has some inherent risks involved....) that is why computers cannot fly a/c under all conditions. You obviously need a human mind calculating the best decision for a given event.
Tail stall occurs when the angle of attack goes excessively negative.
Main wing stall occurs when the angle of attack goes excessively positive.
The pusher only fires at high angles of attack. The pusher should not fire during a tail stall... however if a tail stall leads to an upset it is understandable at some point during the attempted recovery the angle of attack could exceed the amount required to fire the pusher.
It's not impossible at all.....
NOTE WHAT IS SAID AT 31 MINUTES AND ZERO SECONDS.......
http://video.google.com/videoplay?do...31008391&hl=en
I am not so sure about this...
I agree that the stick shaker/pusher activates at and beyond the wing's critical (excessively positive) AOA. But here is the thing... Increased airspeed aggrevates the stalled condtion in the case of a tailplane stall, since it causes the AOA to become more "negative." Since the nose would have been headed downhill during a tailplane stall event, at what point would the critical AOA of the wing have been exceeded? Furthermore, the pusher is inhibited below a certain altitude I am sure (Q pilots help me here?) The aircraft was already at 1500ft AGL... How much time would they have had to have a tailplane stall event, then get the airplane excessively slow so that the stick shaker and pusher activated prior to impact? Maybe if the airplane rolled over... I suppose a high LF could induce a high enough AOA, maybe.
I guess I am just spit ballin' here, but obviously something is missing. I don't think I would have expected a stick pusher activation with a tailplane stall event...
I am really curious to see what the rest of you think.
Why would the stick shaker activate if it was a tail stall, unless it was actually a wing stall? Or is it possible to have both at the same time?
Maybe they stalled the wing when they pitched up to recover from the tail stall.
