The part i dont get, is if there were no pitch control input changes prior to the AP disconnect, why would it pitch up? They were already trimmed for level flight (pitch) and possibly coming out of the initial intercept turn (roll), but still 'in level trim', so if the roll excedence were to cause the disconnect, it seems that the pitch shouldnt change? I think i understand when you say that when they were slowing the trim was compensating for the required trim until it reached a limit but usually when you get a AP disconnect because of limits, the plane stays where it was, whether it be level pitch, or in a 20 degree bank turn, or what have you because thats where it was when it disconnected.. Granted you have to take immediate control to prevent something from happening further. You might be right about the wing stall but the nose would dive and the pilot would yank bank which would address the pitch up reports.
As I see it, the key to your statement is in the first sentence:
"The part i dont get, is if there were no pitch control input changes prior to the AP disconnect, why would it pitch up?"
Actually there were lots of pitch input changes - all made by the auto pilot and unobserved by the crew. [If the darn airplane had a trim wheel they might have noticed it turning] Additionally, the autopilot was struggling to keep the wing from increasing the bank angle (due to the ice on that wing), which they also did not know.
The aircraft was in a descent - through 6000, 4000 to 2300. Power most likely retarded for the descent. Altitude is pre-selected to 2300.
As we reach 2300, altitude captures and is held by the autopilot. What happens now to airspeed? Unless power is added, airspeed will decrease.
If the autopilot was NOT engaged, and you didn't touch the yoke - what would happen to the nose as the airspeed decreases? It would drop off wouldn't it? If you did not want that to happen but you still wanted to slow down. what would you do? Trim nose up.
Now put the autopilot back in the equation. You told it to hold 2300 ft, and it does. As the airspeed decreases how does it do that? It trims the elevator nose up, to hold the altitude.
If you do nothing else it will continue to trim nose up and the airspeed will continue to decrease - until one of the two reaches the level required to hold that altitude with that amount of power. In other words, if the power available matches the power required to hold altitude at that speed, the auto pilot will stop triming and you will be in level flight with x amount of nose up trim and y amount of power - stable. If the power available/used remains less than required - airspeed will continue to deteriorate slowly until the auto pilot runs out of available trim capability or you exceed the critical AOA and stall.
I am only saying how it works - not what they did. I assume that they added enough power to hold the desired speed (or what they thought would hold it).
Everything is now stable and the auto pilot has stopped triming nose up -but - it has NOT removed much if any of the trim previously input. You're still at 2300 ft and headed for the localizer. Glide slope is not alive and has not captured.
As you approach the localizer the autopilot begins a turn to capture it. The auto pilot is still flying. What happens now?
As the bank increases more back pressure is required to hold the altitude. The auto pilot provides in by additional nose-up elevator trim. Something else also happens - the airspeed begins to deteriorate (slow) again. You decide to accept the slightly lower airspeed and you don't add more power - it's already where you think you want it.
Meanwhile bank angle is increasing and elevator is trimming nose-up (slowly). Bank angle tries to increase beyond 25 deg. (due to the ice) until the auto pilot exceeds its limit and kicks off. The nose pitches up and the wing stalls.
Instantly the bank increases from 25 to 45 degrees - further increasing the stall speed. What happens to stall speed as bank angle increases? Yep, its higher than in was before. It was already on the edge - you just didn't know it.
Just as you act to correct the bank the wing stalls. You call for full power and all that up elevator trim is still there. Where does the nose go before you can stop it? All the way to +31 degrees nose up and you have the yoke full forward. There's a lot of power there and some very big props.
Down goes the nose - very rapidly. Your control input has taken effect There is still too much elevator trim for that amount of power and you're pushing hard.
The instant you see 45 degrees nose down you reverse the pressure and pull like hell. You still have almost full aileron cranked in to pick up the left wing. You havent thought at all about trim. Who would?
Just as you apply that back pressure you now enter an accelerated secondary stall. The aircraft snaps to the right - exceeding the vertical bank angle. It is completely out of control - plus you just lost a thousand feet.
The rest ...............
It's all hypothetical ... just a theory.
