InHot
Oh Yeahhhh
- Nov 26, 2001
Cleared Direct
Hey manic,
Great question. I imagine each of us has had this happen at one time or another.
I don't have the "textbook"answer with references, but I hope someone does and will clue us all in.
Hey AVBUG! Where are you when we need you?
My conjecture:
In your example:
The controller says "cleared "direct Boise." My assumption is that you are cleared to the airport becaue he did not give any clearance beyond "Direct Boise". Had he wanted you to go direct to the VOR he would have said:' Cleared direct to Boise, then as filed." (Boise VOR, Direct KBOI).
Of course, my .02 and I don't have a specific reference.
As to the issue of lost comm when cleared direct to an airport, that is covered explicitly in FAR 91.185 IFR operations: Two-way radio communications failure, sub para (c) (3):
What approach do you shoot? Well, under Lost Comm you can shoot any approach for your destionation:
OK Avbug over to you.
Hey manic,
My conjecture:
In your example:
To clarify the situation on what I was filed for KSEA.SEA V4.BOI.KBOI
Leave clearance limit.
(i) When the clearance limit is a fix from which an approach begins, commence descent or descent and approach as close as possible to the expect-further-clearance time if one has been received, or if one has not been received, as close as possible to the estimated time of arrival as calculated from the filed or amended (with ATC) estimated time en route.
(ii) If the clearance limit is not a fix from which an approach begins (ie; KBOS), leave the clearance limit at the expect-further-clearance time if one has been received, or if none has been received, upon arrival over the clearance limit, and proceed to a fix from which an approach begins and commence descent or descent and approach as close as possible to the estimated time of arrival as calculated from the filed or amended (with ATC) estimated time en route.
....proceed to a fix from which an approach begins and commence descent or descent and approach as close as possible to the estimated time of arrival as calculated from the filed or amended (with ATC) estimated time en route.
