Citation down in Milwaukee,
They talk about that in training all the time, if it's up you just bank 90 degrees til she falls level again, doing it over and over til you pull the breaker. Anyone ever had a elec trim nose down runaway, guess inverted might be the only way to control that.
Does that work at 2000 MSL? Sounds like they were low when it happened.
So I take it there is no trim wheel?
There is not some other means of stopping that? Most a/c have a few ways to stop it??
Just curious about the setup, not speculating.......
Very Sad
We should all pray for the crew and passegers first of all. Its easy being a monday morning quaterback in any aviation accident. Yes it would have alleviated the problem in theory by pulling the circut breaker ( On the CA side bottom row towards the front of the panel. Yes the trim wheel can be manually positioned, but when its happening by the time it is realized who knows what anyone's reaction might be. Unfortunatley its how we all learn and hopefully if it happens to anyone else they might be able to react in a manner that will be able to get the aircraft under controll.
God Bless the families of the victims
Sad to hear. I hope the patient can find another donor really soon.
Circuit breakers can be very hard to find in an emergency especially if your company has a bunch of old airplanes with the breakers located in different places like my company. The 90 degree bank technique sounds like a very good idea.
Also, consider switching off the batteries, generators, and inverters if needed; all electrical. It might be easier than searching for a circuit breaker. Hopefully you're VMC; you'll be without instruments for a while, get ready to fly the standby gyro, but it might be the lesser of two problems.
Do the Citations have break away controls like the commercial planes do so If the elevator jammed you could "disconnect" the Capt. yoke and fly with the FO/s yoke?
the patient got a new set of lungs today.
Had the same thing happen to me last month in the Citation VII (no manual backup trim in that, only a secondary pitch trim system) but what happens (as it did with me) if it is a forward runaway pitch trip and not an aft runaway pitch trim? What then? You cannot "unload" the aircraft by banking 90 degrees with a forward runaway pitch trim Crobar. Lucky for me the secondary pitch trim system worked fine.
Don't know about the citation, but this has been a big issue for the CRJ. There is no manual backup on the CRJ and you are out of luck after you disconnect it but it should be controllable assuming you don't let it run to the stop. Extending flaps or opening the flight spoilers are remedies to relieve control pressure, but if the trim goes too far, and depending on your speed, etc., you're probably out of luck. I'm really surprised some of these airplanes don't have manual trim wheels for the pitch axis. Surely a money-saving design by the manufacturers.
I had a similar thing fappen to me in the Lear35, stuck my knee behind the yoke to keep the nose down till I could find the trim switch in the dark. Lucky that I'm 6'3" in a Lear
I guess the pilots reported it to the tower when they declared an emergency. I don't know how much you can rely on what the news says though.
Pilatus doesn't have a manual trim either. This made me feel uncomfortable. No doubt a cost saving measure.
RIP
Ahh it was a C550. They all have a manual trim wheel next to the pilots right knee. It also has a BIG RED trim/AP Disconnect button on the yoke.
Yeah but will the trim disconnect on the yoke stop a runaway trim event? I'm assuming you need to pull the breaker to stop that.
The red button disconects the autopilot and the yaw damp, at least on the CJ2
From Page 5E9 from the Simuflite Initial Pilot Training Manual for the II/SII:
The AP/TRIM disconnect switch on the pilot and copilot's yoke electrically disables the electric trim if a malfunction in electric trim should occur. Pulling the 5 amp PITCH TRIM CB on the left circuit breaker panel removes power from the electric trim motor.
This still left me with a few questions so furthermore;
From Page 5E19:
Electric Elevator Trim Failure / Runaway Trim
If an electric elevator trim runaway occurs, press and hold the AP/TRIM disconnect switch on the pilot's or copilot's control wheel. The switch removes electrical power and stops movement of the electric trim. Remove electrical power to the elevator trim system by pulling the PITCH TRIM CB. After removing power to the electric trim motor, release the AP/TRIM disconnect switch. Continue the flight using manual elevator trim.
Also, PITCH TRIM CB is located on the Captain's Side CB Panel, bottom row, sixth from the left side, fourth from the right. The CB panel layouts changed after S/N 626, the accident aircraft was S/N 246.
Personally, I'm having a hard time believing it was runaway trim. Hold the big red button, pull the plug on the CB, problem solved for the time being. Oh well, I guess the NTSB will take it from here and start looking at maintenance, tapes, etc. Godspeed.
From Page 5E19:
All true, and also, the electric trim CB is located by the pilots left hand, and should be collard for easy identification.
Likely scenario
My guess is the autopilot was engaged at the time of the runaway. In a 550 the autopilot will hold it as long as possible. If your quick you might see a autopilot torque light. Once to much torque is put on the autopilot it will disconnect itself. At 2000 ft agl the pilot wouldn't have much time to react to this. When the autopilot kicked itself off the pilot would have a heck of a time controlling it. Anyhow godspeed to the crew, and I'm happy to hear the patient got a new set lungs!
Funny how important CBs like those are often mixed in with RT PITOT HEAT and AFT LAV FAN and not in some easy to remember position, like A1. I mean why does it always have to be somewhere like row 2, 6 from the left.
Yes
I had a similar event in a Lear 31. The auto pilot was counteracting the trim until the forces become to great, then out of nowhere it disconnects and you are on your own to figure out why it did, what is happening, what to do to correct it. It can be a major overload that happens in seconds. Any word on the other 2 Citation accidents. I heard this is the 3rd in a month.
Doesn't the ap use the pitch trim for elevator control? How would the ap compensate for a pitch trim run away?
Just got my alumni magazine today in the mail and realized that I went to college with one of the doctors on that Citation. Not sure if I ever had a chance to meet him though. A terrible tragedy.
