CDNJetPilot
Active member
- Jul 8, 2002
Once again, look at your photos closely and you can see the mid level cloud is BELOW the contrail. It's so visible and I'm only using your crappy little photos. Spend some time looking at this, you can see where the thicker parts of the clouds obscure the contrail.
Denver, I think you need a long holiday. You exhibit some neurological signs that aren't healthy. I don't trust the government that much either, but the photos you keep posting throw your arguments out the window. Until you really stop ignoring all the math posted here, and get in a plane, get air samples of these contrails - and normal contrails, then have a lab pour over the data can you really start spouting off what you claim. Also, you'd have to collect samples from all over the nation to really have a good random set. These junkie photos are hardly any evidence to create a basis for what you believe. By showing these simple photos as your base case, there is no weight whatsoever to this argument. I suggest finding some serious funding, rent some airplanes and air sample equipment and start collecting data which can then be audited by independent labs. Good luck and I'm curious as to the results. Merry Christmas. Try to relax a little. Get a good book and maybe a good bottle of wine and think about all this before getting so worked up about it. Until you can really prove anything with scientific data don't put yourself into a heartattack.
