Caravan Performance Data
pilotyip
Anyone know where to get performance data for a C-208 Caravan? Preferably free
Skinny, fast wing that can't lift........
Gear down so you can't go fast...............
Terrible on floats...
yeah, thinking the same thing...performance data here
SLOW, Can land on a dime, and oh yeah, it goes slow
flt plan stuff
Watcha need...
flight planning, How much gas to go so far at 10K'. vs payload, dest fuel alternate fuel, reserve etc, by putting numbers into a computer. Takes into effect winds, temps etc.
Used to plan 350-400 lbs first hour then 300 thereafter fuel burn. 1000 lbs of fuel gives you 2:45 of endurance with 3000 lbs payload. fltplan.com has C208 flight planning info. If you're heavy plan 5000 to 6000 feet for altitude, 10k will take too long to climb. TAS is 160 around 5k to 6k. Max fuel is 2400 lbs. Let me know if you need more info.
Nolife...Whatup! 5000 to 7000 ft in the C208 is average for a 1 hr 160 NM flight, climbing to 10k is not worth the time and fuel. I've never flown with 3000 lbs payload, 70% of the time you bulked out around 2500 lbs (avg size shipping boxes), unless you're flying nuts and bolts...then you'll weight out with 3000 lbs easily.....
