Brakes work...
What is up with all the HEAVY braking during landing on so many regional flights?
Many regionals normally use minimal (ie idle) thrust reverse on landing, which is much different than one typically sees flying bizjets. This is to save engine wear and extend mean time-on-pylon.
It also could be in order to make a high-speed or convenient taxiway that helps the operation of the airport (like exiting before crossing RW13 after landing RW4 @ LGA).
crjdude
SOP for some regionals is the use of idle reverse to prevent or mitigate FOD damage and engine wear. When you couple that along with not wanting to hang out on the runway, you get heavy braking. But not to worry, airman, all that was briefed after I put my laptop away and woke the captain.
I did it because it was fun, for the lulz as they say.
crjdude
Just trying to give you one last good close-up of the many handy items (which you never would have guessed you could live without) contained in the latest crisp issue of SkyMall.
-Gots to make sure RA's poolboy gets paid!
Brake Shoes
It's a result of deregulation. Time was, pilots could afford imported shoes made of soft Corinthian leather. These days, a pair has to last ten years or more, causing a switch to heavy lumberjack boots or clodhoppers. Gentle braking is nearly impossible. :D
True... especially in the winter. Because my airplane is so small and doesn't attach to a jetway easily, I have to traipse my way through inches of snow and deicing fluid.
crjdude
99.9% of my flight i have ATC telling me to expedite to clear the runway. It's always rush rush rush. Expedite to your gate etc....
Now I couldn't care less. Pax and brakes come first. Screw ATC.
Perhaps it is a result of the Captains taking control of the airplane around 60-80 knots on the landing rollout to "taxi" it off and the resultant disconnect that occurs between what the FO thinks the Captain wants and what the Captain actually wants. I'm just sayin...
I don't get paid any more to make 'em smooth, so I get my money's worth with every chance
There is no reason for you to do that other than trying to be deuch. Be careful so that you don't get behind one of your types when you have low fuel and going around is not an option. Karma is a real lady.
Take it as a sign. This is like the old guy (wearing a hat) driving slow in the left lane on the 405 and can't for the life of him understand why so many people honk, tailgate and give the 'hi' sign these days.
You have severe problems if you ever get to this point.
You are missing my point. It gets very tiresome being told to expedite all the time.
ATC is micromanaging us to death. Left 10 degrees, right 5 degrees. Slow to 180, slow to 170, speed up to 180. Left 5 degrees. Slow to 150.........Expedite off the runway. WTF????
Day in and day out, it gets old.
If your that low on fuel then declare! I will be more than happy to get out of your way.
i was told to expedite off the runway once and i said "sure, but ill need a billing address to send the invoice for my new brakes" then ATC said " uh, roger, left turn when able and contact ground point 7" ..... true story, try it one day.
Thanks anyway, I'd rather not...
They're doing this to get you on your way a little sooner.
Would you prefer we're all 20 miles in trail with a 4-hour EDCT?
Yea, we have 30 mile finals anyway. Flying at 150. Then they tell me to expedite. Whatever!!!!
Just thought of an old saying from a famous old basket ball coach..... "Be quick - but don't hurry!" ~John Wooden.
when its -58 C upstairs the RJ's don't heat your feet well.. the hard braking is simply due to partial frostbite and no feeling in one's feet..
the braking will get smoother later in a month or so...........
get on a bigger airplane.....
less vectors.
WOW!
you are the man!
