talondriver
- Nov 3, 2002
psysicx said:Is the tanker unit in Portland Oregon going away?
This is straight from the BRAC detailed report:
Portland International Airport Air Guard Station, OR
Recommendation:
Recommendation:
Realign Portland International Airport Air Guard Station, OR. Realign the939th Air Refueling Wing (AFR) by distributing the wing’s KC-135R aircraft to the 507th AirRefueling Wing (AFR), Tinker Air Force Base, OK (four aircraft); the 190th Air Refueling Wing(ANG), Forbes Field Air Guard Station, KS (three aircraft); and by reverting one aircraft tobackup inventory. Operations and maintenance manpower for four aircraft from the 939th AirRefueling Wing is realigned with the aircraft to Tinker Air Force Base. The 939th Air RefuelingWing's remaining manpower, to include expeditionary combat support, is realigned toVandenberg Air Force Base, CA....
It then goes into the 142 FW realignment. Albie can probably clue you in on that.
