It sounds like Bloch cannot change the award, but only interpret its application as we go forward.
Just reading the Bloch award it would appear that 9E and XJ are both below the 279:95 ratio which triggers a ratio of 279:95 down to 41 aircraft. This would leave about 200 XJ 900 captains and 68 9E 900 captains. (41 aircraft)
The big question is as the new 900's come on line how do the ratios apply?
I have a couple thoughts on this:
First: he could direct that as the award states 279:95 applies until both XJ and 9E are above those numbers which would be 57 900's. The rest of the spots would go to Colgan, Pinnacle, and Mesaba in seniority order with 9E carrying the most spots from 57-81 aircraft.
Second: he could direct that as the award states 279:95 applies until both XJ and 9E are down to 200:68 (41 aircraft). The rest of the spots would go to XJ,9E,and Colgan in seniority order. XJ would do well up too around 350 seniority number because that's were the second group on the list would come in. 9E would then do well because they populate most of the list up to the 570 captain positions required with 81 aircraft. His reasoning could be that the 40 900's are all new aircraft that the combined group procured.
Third: he could direct that as the award states 279:95 applies until both XJ and 9E are down to 200:68 (41 aircraft). He could then say that the new
900's are a direct substitution for 9E 200's and the 541:100 ratio will apply to the 40 additional 900's. (this option almost seems like a re-write rather than interpretation to me but I am probably biased being prior XJ)
Whats everybody think?
