Fugawe
- Dec 27, 2005
9GClub said:In theory you're supposed to apply 'downwind' rudder to eliminate the crab at the last second before touchdown, but no airliner I've ever watched has landed without a significant degree of sideslip-- or maybe not sideslip per se, but at least a ground track that runs slightly diagonally across the runway (i.e. not parallel to the centerline). They always touch down and then kick in rudder to line it up. What's the deal? Are these guys just not kicking the pedals before touchdown, or is a sideslipping touchdown just more acceptable in larger aircraft?
You're just not able to notice the rudder use, the pilot should have the crab out at touchdown and be aligned with the centerline when the mains touch.
Undaunted's post is correct -- the # 3 technique is used on any airliner I've flown (by most pilots anyway). Remember, it's all 'technique', but the one in the ops manual or PIH is usually the best one.
How much rudder is used, and how aggressively or how early it's applied depends on the winds. Steady light winds require only a last second application/correction. Heavy winds - a little sooner (maybe 3-5 secs before touchdown). Gusty winds require work all the way down short final to touchdown and beyond.
Few airliners or GAA aircraft are designed to handle crab landings (gear sideload problems). Fighter type jets have to land in a crab because of wing sweep, and are designed for it. The 777 guidance for winds over 31 knots direct cross (38 is current max), you accept a little crab in the landing to avoid maxing out the ailerons or having the upwind wing too low.
Xwinds are challenging sometimes. Best is to squeak one on, taxi in, then have the pax or FAs see crap blowing around and comment that they didn't know it was so windy. Just smile to yourself -- you could try explaining to them that it was a chore getting them smoothly on the ground -- but, chances are they'd not understand, or not care.
Fugawe
