AirplanesSuck
Malevolent Matriculator
- Sep 17, 2006
Thanks, that is a perfectly logical line of reasoning. To be clear, I was trying to reconcile that with this section:
This is of no event when towing a banner. As previously, it's of no consequence and poses no danger at all unless the pilot elects to make it dangerous. A flight from A to B in a single engine airplane is just the same. The act of going from A to B, of it's own accord, not a problem. The pilot who complicates it by undertaking the flight in an airplane with limited options and performance, and who does so with limited alternatives in equipment and redundancy paints himself into a corner, and thus makes the flight dangerous. Again, it falls back to the pilot.
You must not be a good enough pilot to appreciate his greatness.
Anyway, whoever thinks single pilot night IFR is dangerous, must not be a good pilot. Probably blames systems failures on banner pilots.
CE
Jeesh I think dual pilot VFR day is scary as hell!!!!!!!!!!!!!
God, I need a less scary occupation. Maybe I could open an ice cream shop that seems low risk.
Towing is certainly more dangerous than many other flying jobs.
Uh-oh...
Standby for AvBuggery....
I towed in 14Papa for many hundreds of hours in 1999, I did pay $1500. for training.. but they teach you how to safely do the job and not kill yourself, nothing dangerous about towing banners if you're in a Super Cub and have the proper training.
NTSB Identification: SEA08LA192
14 CFR Part 91: General Aviation
Accident occurred Sunday, August 31, 2008 in Camarillo, CA
Probable Cause Approval Date: 8/13/2009
Aircraft: PIPER PA-18-150, registration: N7482D
Injuries: 1 Fatal.During a banner pickup maneuver, witnesses observed the airplane level off from the descent about 150 feet before the banner pickup loop, then rotate and catch the banner pickup loop with its main landing gear instead of the tail hook. Witnesses stated that as the banner started to lift, the pilot added full power and began a climbout at a 45-degree angle to an altitude of about 150 feet. The airplane was then observed to level off before the nose suddenly dropped to about a 30-to-45-degree nose-down attitude before impacting the ground. One of the pilots who witnessed the accident said that it appeared that the pilot might be trying to land straight ahead but did not level off prior to ground impact. According to company procedures, the pilot is expected to establish an approach speed of 80 to 85 mph, maintaining a 15 degree to 20 degree approach angle until the rotation point at the banner pickup loop, and establish full power before rotating. Rotation serves to swing the hook down and forward to snag the rope, as opposed to a flat approach that drags the hook across the rope. As the airplane rotates, the nose is to be raised approximately 20 degrees to 30 degrees above the horizon. At 150 feet, the power is pulled back and the airplane smoothly leveled off at an altitude of 200 feet where full power is then applied. A postaccident examination noted no preimpact anomalies with the airframe or engine which would have precluded normal operation.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
The pilot's failure to fly the correct approach profile that resulted in the inadvertent pickup of a banner tow line with the airplane's main landing gear.
According to the company's Director of Operations, the accident pilot had accumulated a total of 260.2 hours of banner tow time in the PA-18 airplane during his employment with the company. Company records also indicated that the pilot's most recent recurrent training occurred on January 13, 2008, which consisted of 0.5 hours of ground instruction, with the training form annotated, "[The pilot] was observed later picking a banner with N105F, and he demonstrated proper safe operational procedures as discussed." Additionally, the pilot received recurrent training on October 12, 2007, which included 0.5 hours of ground instruction and 0.5 hours of flight recurrent training on "banner pick profile and procedures," which was conducted by the company's chief pilot. The chief pilot noted, "At issue is [the pilot's] picking a banner with the main gear. [The pilot] did a successful job demonstrating safe operational procedures." A statement submitted to the IIC by the company's Director of Operations confirmed that the accident pilot "...did in fact have an issue back in October 07, when operating in Waco, Texas, he picked a banner up with the main gear and had to land with the banner."
Is this the procedure? http://www.youtube.com/watch?v=-YyMH167rPw
Hard for me to see how one could catch the rope on the mains?
