Nova
Ops Check Good
- Jul 3, 2002
TonyC said:I answered that question previously, but you seem to be bent on ignoring it. The absolute altitude is irrelevant. When you have 29.92 set on your altimeter, you are reading pressure altitude, and you can enter the table directly. If -44ºC is the standard temperature for 30,000 feet, then it's the standard temperature for FL300. It's just that simple.
It was my error that I stated absolute altitude when I meant to say true altitude. The charts you listed for standard temperatures at altitude are based on True Altitudes while we are flying along at Pressure Altitudes. True and Pressure altitudes will only match when atmospheric pressure and tempreature are standard.
Say you are flying at 17,999' with the current altimeter setting of 29.42 set in the Kollsman window and notice that the OAT is -5 F (standard). That gives you and ISA +0. Now you are cruising at FL180 and tune 29.92 into the Kollsman window. You now find your true altitude to be 17,500' yet you are flying a pressure altitude of 18,000' (high to low look out below). Your OAT will now be reading about -3 F or so. Technically you are still ISA +0 since your OAT is correct for your true altitude. Your method gives you an ISA +2 since you are indicating 18,000 and your standard temperature lists -5 F as the standard temperature.
From what you are saying FL180 = 18,000 feet when it comes to calculating what the standard OAT should be. In nonstandard pressure situations that isn't the case and the charts you list don't account for that. In the flight levels you are flying a isobaric surface not a fixed true altitude. Unless you know the outside air pressure how will you calculate your true altitude? Like temperature, pressure doesn't necessarily maintain a standard laps rate but the rule of thumb may get you close. Plugging in the local altimeter setting from the airport 7 miles below you probably isn't very accurate.
Now the same could be said for temperature variations but the same quote applies, high to low look out below. Here's a refresher:
http://virtualskies.arc.nasa.gov/weather/tutorial/tutorial2d.html
So on a cold, low pressure day you are actually flying quite a bit lower true altitude with the same indicated. I know a few pilots at work who are baffled by the early appearance of the Mmo red line at 10,000' on those days. Given a nonstandard pressure at altitude and large ISA deviation you may have trouble climbing those last few thousand feet to cruise but I guess reading your OAT tells you all of that.
