CarjCapt said:3. And as "Fins" says the very most important issue is "SCOPE"
You will be much better off in the long run if you make sure Delta Air Lines
is part and parcel of your scope language.QUOTE]
But just remember, no pilot group can have scope over the DL code, only their own aircraft. That would be predatory. DL should be allowed to RFP all of their code. Well at least according to the RJDC.
1. Can the DAL pilot group, or any pilot group own/control their code?
In a word, NO. The “code” under which your airline operates is not owned by the Delta pilots and it is not controlled by the Delta pilots. The “code” is owned by Delta Air Lines, Inc. and they alone “control” it. The same applies to other “codes” owned by other airlines.
