whatitdoing?
Are you awake? Good
- Feb 18, 2006
Ok, before I spank the monkey....ie....you amcnd, let's begin with what I said on my post. If you re-read my post, you'll see that I say 30 LCP's. That's LCP's, not IPs. Since the seperation of the training department, you're either a LCP or an IP. Hence, you have no idea what YOU'RE talking about. You are correct to say that ASA has more than 30 "flight training" pilots under the umbrella of the Training Department. But, there is a difference. So, again.....who's your momma? About the Mormon church, you're again wrong. No one, beside an idiot....ie...again.....you......can say that the Mormon church doesn't have a HUGE influence on Skywest Inc.. Since every board member beside 1 is a member of the Mormon church, how much influence do you think the church has on Skywest priorities? I'm guessing ALOT. So, I'll retard it for you. If you have a board that is comprised of many members of a "cult" and you have MANY employees as members of a "cult", then wouldn't you say the church has a royal flush with Skywest Inc.? Damn, spanking the monkey is fun AMCND. Third, I assume you're right about many instructors in SLC since it's shrinking. But being there's only 2 that are based there, that wouldn't be a lot. You might see other LCP's, not IP's out there doing line checks, but they are probably DHing in. So you're assumption of there being tons of IPs (you're again wrong because they're LCP's) out in SLC is yet again untrue. You let me know when the monkey has had enough........
