uwochris
Flightinfo's sexiest user
- Dec 21, 2001
MacGyver...is that you?uwochris said:Hey guys,
Can someone explain the difference between alternating current and direct current output? I just don't really understand why some systems require AC, while others require DC. What makes one system require one type of power input, but not the other?
Thanks in advance.
Jafar said:Direct current flows one way. Alternating current alternates directions, forward and back(Once every 50th of a second). Almost all household appliances use DC at some stage in the circuitry by converting the AC to DC. AC creates electromagnetic fields that can be useful in circuits that don't require or use a constant, unchanging flow of electrons. With AC it is also easier to vary voltages through the use of transformers.
Hope that helps, it's been a couple years since I took electromagnetism so it isn't real fresh...
tarp said:AC power by it's nature can send vast amounts of voltage (power) at very long distances.
tarp said:DC power conversely is very difficult (and heavy) to send high power long distances.
tarp said:Batteries by their nature are DC. However, you can change DC to AC by using an "Inverter". You can change AC to DC using a "Rectifier".
tarp said:Your question can have a thousand answers.
Col. W.E. Kurtz said:I watched a snail crawl along the edge of a straight razor. That's my dream. That's my nightmare. Crawling, slithering, along the edge of a straight... razor... and surviving.
