uwochris
Flightinfo's sexiest user
- Dec 21, 2001
MacGyver...is that you?uwochris said:Hey guys,
Can someone explain the difference between alternating current and direct current output? I just don't really understand why some systems require AC, while others require DC. What makes one system require one type of power input, but not the other?
Thanks in advance.
Jafar said:Direct current flows one way. Alternating current alternates directions, forward and back(Once every 50th of a second). Almost all household appliances use DC at some stage in the circuitry by converting the AC to DC. AC creates electromagnetic fields that can be useful in circuits that don't require or use a constant, unchanging flow of electrons. With AC it is also easier to vary voltages through the use of transformers.
Hope that helps, it's been a couple years since I took electromagnetism so it isn't real fresh...
tarp said:AC power by it's nature can send vast amounts of voltage (power) at very long distances.
tarp said:DC power conversely is very difficult (and heavy) to send high power long distances.
tarp said:Batteries by their nature are DC. However, you can change DC to AC by using an "Inverter". You can change AC to DC using a "Rectifier".
tarp said:Your question can have a thousand answers.
Col. W.E. Kurtz said:I watched a snail crawl along the edge of a straight razor. That's my dream. That's my nightmare. Crawling, slithering, along the edge of a straight... razor... and surviving.
cynic said:The simple explanation you were probably looking for is...
Direct current flows one way in a cirlce. So positive lead on the airplane battery goes to electrical stuff and then returns to negative lead. The power travels around in a cricle.
Alternating current (into your house) has a single wire from the power station and the power goes back and forth over a single wire. There is no negative wire back to the power station.
http://science.howstuffworks.com/electricity1.htm
mzaharis said:EPilot22, I love that story. We always have this saintly image of Edison, but he could be an SOB when it came to competition.
Go make crazy faces and wave your arms wildly in front of a TAZER toting traffic cop and let us know how you do.:nuts:ePilot22 said:I wonder what it'd be called when we got shocked?
Meathead said:A Squared: You are scaring your compadres - Not to hack on you, but Tarp is exactly correct.
Meathead said:AC power has 2 principal advantages:
1) Less efficiency loss in transmission (very significant over long distance) and
2) Smaller conductors required to transmit the same power (equals smaller wire or cable size, and smaller and lighter motors as compared to the DC equivalent)
Meathead said:This is why AC is used on larger aircraft, as well as for bulk power transmission (ie across the country). Precisely for the purpose of limiting heating losses (and transmission line sag), voltage for most transmission systems is 345000 volts AC (or even 510kV way out west).
h25b said:The whole reason for the introduction of AC power was to transport electricity over long distances.... ASqaured, read this...
A Squared said:Right, both of the articles say exactly what I've been saying. It's more efficient to transmit high voltage electricity than low voltage electricity, and DC is extremely difficult to step up to higher voltages. I didn't read every word, but I don't beleive either of the articles says that the fact that the current alternates makes transmission more efficient (and if it does, it is wrong)
DaveJ said:h25b you're missing the point. It's not whether the current is AC or DC that matters. Low voltage/high current will have more losses than high voltage/low current regardless of whether it's alternating or direct current. AC is much easier to step up or down in voltage than DC and so is the more commonly used.
AC has some other advantages as well with respect to constant speed electric motors.
A Squared said:Nope. There are a lot of reasons why AC power is used for transmission, Efficiency isn't one of them. A 510KV DC transmission line would be exactly as efficient as a 510KV AC transmission line.
h25b said:I don't think this is true... To end up with 510KV at the end of the line you'd need to start with 510KV at a much higher amperage at the beginning of a given power line... To end up with that same 510KV at the end of an AC power line you don't have to do it at nearly as high of amperage. This is why they use AC instead of DC. If they used DC they'd have to have power plants along the way to keep the amperage high enough so you end up with the proper voltage at the end.
h25b said:Maybe I am confused. But I am speaking in terms of power transmission. If DC is as efficient to move along a given medium then you'd be saying that placing power stations every couple miles would be a good way to distribute electricity ??
A Squared said:DC *is* as efficient as AC, when comparing similar voltages. It's just that it's D@mned difficult to produce 510KVolt DC without a thunderstorm. At any rate, mzharris said pretty much what I was going to say, perhaps better.
