GogglesPisano
Pawn, in game of life
- Oct 20, 2003
Meathead said:A Squared: You are scaring your compadres - Not to hack on you, but Tarp is exactly correct.
Meathead said:AC power has 2 principal advantages:
1) Less efficiency loss in transmission (very significant over long distance) and
2) Smaller conductors required to transmit the same power (equals smaller wire or cable size, and smaller and lighter motors as compared to the DC equivalent)
Meathead said:This is why AC is used on larger aircraft, as well as for bulk power transmission (ie across the country). Precisely for the purpose of limiting heating losses (and transmission line sag), voltage for most transmission systems is 345000 volts AC (or even 510kV way out west).
h25b said:The whole reason for the introduction of AC power was to transport electricity over long distances.... ASqaured, read this...
A Squared said:Right, both of the articles say exactly what I've been saying. It's more efficient to transmit high voltage electricity than low voltage electricity, and DC is extremely difficult to step up to higher voltages. I didn't read every word, but I don't beleive either of the articles says that the fact that the current alternates makes transmission more efficient (and if it does, it is wrong)
DaveJ said:h25b you're missing the point. It's not whether the current is AC or DC that matters. Low voltage/high current will have more losses than high voltage/low current regardless of whether it's alternating or direct current. AC is much easier to step up or down in voltage than DC and so is the more commonly used.
AC has some other advantages as well with respect to constant speed electric motors.
A Squared said:Nope. There are a lot of reasons why AC power is used for transmission, Efficiency isn't one of them. A 510KV DC transmission line would be exactly as efficient as a 510KV AC transmission line.
h25b said:I don't think this is true... To end up with 510KV at the end of the line you'd need to start with 510KV at a much higher amperage at the beginning of a given power line... To end up with that same 510KV at the end of an AC power line you don't have to do it at nearly as high of amperage. This is why they use AC instead of DC. If they used DC they'd have to have power plants along the way to keep the amperage high enough so you end up with the proper voltage at the end.
h25b said:Maybe I am confused. But I am speaking in terms of power transmission. If DC is as efficient to move along a given medium then you'd be saying that placing power stations every couple miles would be a good way to distribute electricity ??
A Squared said:DC *is* as efficient as AC, when comparing similar voltages. It's just that it's D@mned difficult to produce 510KVolt DC without a thunderstorm. At any rate, mzharris said pretty much what I was going to say, perhaps better.
