- Dec 21, 2001
So does the E120The 727 has two rudders.
I'm guessing you have not had any flight test experience. Simple question - would you want to design/fly/ride-in an airplane that would allow full deflection of a control surface to exceed the load limit of the accompanying structure? (assuming you are within the flight envelope of the aircraft)?
I'm sure that's exactly the gist of what he is saying. It seems that you are disagreeing with something that you actually agree with. By the way what do you mean by "flight test experience"? Hopefully not this type...
http://www.bea.aero/docspa/2008/d-la081127ea/pdf/d-la081127ea.pdf
nor this type...
http://markpknowles.com/first-airbus-crash-photos/
nor...
To modify Boris Marshalov: This internet thing is so strange. A man writes his opinion, nobody really reads it carefully - and then everybody disagree...
It appears that the Forward attach point is still on the tail. I am guessing that if the aircraft hit the water intact that point would be missing as the leading edge would be the first part to hit the water.
I am guessing that they will be able to tell a lot about when the tail separated from the aircraft just by how certain components failed, and how they broke. Science will go a long way to determining the most probable cause of this accident.
That looks a lot like AA587's tail. I'm a bus guy but I'm not smart enough to know what faults would be generated if the vertical stab separated in flight. The first acars messages were as followed (this list was borrowed from another site):
02:10Z:
Autothrust off
Autopilot off
FBW alternate law
Rudder Travel Limiter Fault
TCAS fault due to antenna fault
Flight Envelope Computation warning
All pitot static ports lost
02:11Z:
Failure of all three ADIRUs \
Failure of gyros of ISIS (attitude information lost)
02:12Z:
ADIRUs Air Data disagree
02:13Z:
Flight Management,
Guidance and Envelope Computer fault PRIM 1 fault SEC 1 fault
02:14Z:
Cabin Pressure Controller fault (cabin vertical speed)
The sequence and type of messages could be explained by the loss of the vertical stab. Now the question becomes what caused the stab failure? (If that in fact is what happened)
Boeing stock is up because the 787 flight test program is projected to start this month.
