• NC Software is having a Black Friday Sale Event thru December 4th on Logbook Pro, APDL - Airline Pilot Logbook, Cirrus Elite Binders, and more. Use coupon code BF2020 at checkout to redeem 15% off your purchase. Click here to shop now.
Air France tail found. Wow looks like a clean break....
A-V-8
Total Time
7000
Is the black box located in or near the tail on an A330?
greenlight
Active member
Total Time
7000+
That looks a lot like AA587's tail. I'm a bus guy but I'm not smart enough to know what faults would be generated if the vertical stab separated in flight. The first acars messages were as followed (this list was borrowed from another site):
02:10Z:
Autothrust off
Autopilot off
FBW alternate law
Rudder Travel Limiter Fault
TCAS fault due to antenna fault
Flight Envelope Computation warning
All pitot static ports lost
02:11Z:
Failure of all three ADIRUs \
Failure of gyros of ISIS (attitude information lost)
02:12Z:
ADIRUs Air Data disagree
02:13Z:
Flight Management,
Guidance and Envelope Computer fault PRIM 1 fault SEC 1 fault
02:14Z:
Cabin Pressure Controller fault (cabin vertical speed)
The sequence and type of messages could be explained by the loss of the vertical stab. Now the question becomes what caused the stab failure? (If that in fact is what happened)
crj567
Is this the same type of plane that lost its tail over queens in NY right after 9-11?
Makes you wondering if they exaggerated that story about the FO horsing around with the rudder to cover up for poor design by the French? I sure wouldn't put it past the modern P.C. version of "international goodwill."
-Too early to judge, but damn if that whole thing didn't just break right off-just like that American crash over queens.
B6Busdriver
pushbutton pusher
Total Time
>1
Nope. The AA aircraft was an A300, AF is an A330. Totally different animals.
BigMotorToter
Total Time
11000
Not that different in regards to the tale.
Same company built both planes and I think both tails are composit tails?
PeanuckleCRJ
Hurrrrrrrr
Total Time
mucho
Both the 330 and 300 are composite. What will be tell-tale is where the vert stab/rudder is located in proximity to the rest of the wreckage.
Then you end up with the question of whether the accident was causedby it separating or whether the already dying/dead airplane caused the tail to separate.... or whether it was just sheered off when it impacted the water.
Regardless.... that is a super clean break and the rudder even remained intact.
Draginass
Total Time
5000+
Looks like massive structural breakup midair. It's amazing that the rudder is in such good condition regardless of where it departed the structure.
another cfii
Total Time
5000+
Let's hope they find the blackbox sooner than later. I hope the families will not let the bureaucrats bury the findings on this accident. If some of the conjectures on here are correct, it may even shed some new light into the AA A300 crash in NY as well.
ImbracableCrunk
Unregistered Un-User
Total Time
6AM
That was very well done.
Yeah, that was.
I thought the AA A300 broke down where it was mounted to the fuselage. This looks like it sheared off well above the mountings.
Lear70
JAFFO
Total Time
4abeer
It did and yes, it does.
I'd like to know where the tail section was found in proximity to bodies and aircraft debris...
IF it came off in flight, there's no telling how far away the rest of the tail section (and the CVR / FDR are at), although I'm sure they can draw some estimates based on altitude of the aircraft in cruise, maximum glide range (assuming it didn't just corkscrew straight down at that point) if the vert stab came off first and the rest of the aicraft didn't come completely apart when the vert stab came off, and drift speed of ocean currents.
If the vert stab separated when it hit the water (and the tail was close to the area of bodies recovered), they might have a pretty good chance at finding the FDR and CVR.
180ToTheMarker
12 months of October
Total Time
10K
02:10Z:
Autothrust off
Autopilot off
FBW alternate law
Whoa...hand flying thru severe wx and turbulence without rudder protection (I assume)....makes you go hmm...
fly4surf
Total Time
lots
Maybe 'they' knew we would go hmmm.....
and blame a heavy footed and incorrect pressure on the pedals again?
Instead of what it really is (or seems to be.)
PHXFLYR
USAir by default
Total Time
>0;<1
...and everyone at work wonders why I wish we had Boeings .....:(
PHXFLYR:cool:
Abernathy
Truthiness
Total Time
Lots
Or maybe not. What aim would terrorists achieve if they never took responsibility for an action and no one knew it was an act of terrorism...
Doesn't make any sense for this to be terrorism.
