I think that's a good point. One the one hand, you're a bad pilot if you have to go around and should be ashamed of yourself. On the other hand, you're a bad pilot and a fuel waster if you have to spool up the engines above 500' agl. That doesn't leave a lot of room in between for most mortals. I'm not saying those are my perceptions, but I do think those perceptions exist.h25b said:This seems to back up something I've notice in the industry in general. This idea that performing a GO-AROUND or MISSED-APPROACH is some sort of failure. I had a guy tell me that it scared the passengers before...
I think that 1000' above TDZ is the minimum stabilization requirement for an ILS, and especially in that weather! With ceiling at 100', that means they were descending on the approach lights.AA717driver said:Singlecoil--At most airlines, you have to be stabilized by 500'. Engines spooled up and on the Loc and G/S.
Guys, the G/S had to be pegged at the top way before they hit. The CA blew it by not calling go-around sooner. I was always taught that if you start a go-around, finish it. Even if your wheels touch the runway, don't stop.
The FO was apparently out to lunch, too.TC
P.S.--Anyone want the rest of my furlough passes? I'll stick to riding on China Air or Aeroflot. I think they're safer...
Can I take my wife? I'm a gambler!AA717driver said:P.S.--Anyone want the rest of my furlough passes? I'll stick to riding on China Air or Aeroflot. I think they're safer...
....demonstrating, in fact, that only a pilot with superhuman skills would be able to recover from a sudden autopilot-induced pitch down at 300agl, which can be blamed on the autopilot desensitization rate of the 727.TWA Dude said:From the NTSB report for AA1340, 2/9/98 at ORD: "The National Transportation Safety Board determines that the probable cause of this accident was the failure of the flight crew to maintain a proper pitch attitude for a successful landing or go-around. Contributing to the accident were the divergent pitch oscillations of the airplane, which occurred during the final approach and were the result of an improper autopilot desensitization rate."
I'll take your furlough passes anyday. Between China Air and KAL, something like 1000 pax have been killed in the last 15 yrs. And just make sure your Aeroflot captain is not taking his kids on the trip.AA717driver said:Singlecoil--At most airlines, you have to be stabilized by 500'. Engines spooled up and on the Loc and G/S.
That restriction must have been specific to a carrier or subsequently lifted, as our 727s can perform Cat I, II, or III Autolands.aa73 said:As a result of that hull loss, Cat 2 autopilot approaches were discontinued on the 727.
I don't understand your argument. The NTSB, not me, determined that the pilot failed to correct for the autopilot's pitchdown. They apparently didn't think such a thing required "superhuman" skills.aa73 said:....demonstrating, in fact, that only a pilot with superhuman skills would be able to recover from a sudden autopilot-induced pitch down at 300agl, which can be blamed on the autopilot desensitization rate of the 727.
Doesn't matter whether they think it required "superhuman skills" or not. The infamous Pilot Error label sometimes does not take into account certain conditions in which we do not have the time to react. Case in point, you are probably familiar with this one, the TWA DC-9 in BNA in '99.TWA Dude said:I don't understand your argument. The NTSB, not me, determined that the pilot failed to correct for the autopilot's pitchdown. They apparently didn't think such a thing required "superhuman" skills.
True. It was an AA decision as a result of the accident.TonyC said:That restriction must have been specific to a carrier or subsequently lifted, as our 727s can perform Cat I, II, or III Autolands.
and that is in VMC!!!! IMC would be more like 1000'
oops...i didn't bother reading the rest of the posters who already chimed in!
Actually, the NTSB does take into account situations where a pilot should reasonably be able to react. It's not my intent to slam the captain of that 727 but the fact is that the a/p started deviating and the NTSB believed he had time to react appropriately.aa73 said:Doesn't matter whether they think it required "superhuman skills" or not. The infamous Pilot Error label sometimes does not take into account certain conditions in which we do not have the time to react.
I'm actually very familiar with that incident/accident after having flown with one of the ALPA accident investigators. The FO screwed up in a big way, yet the captain also bore responsibility since he wasn't covering the throttle quadrant with his hand. To be fair, up to that point practically no captain did so even thought it was in the FOM because nobody expected an FO to do something so stupid. (The idiot was fired because he refused to accept responsibility and claimed he'd been taught to pull throttles to idle at 100AGL, which was a lie.)Case in point, you are probably familiar with this one, the TWA DC-9 in BNA in '99.
I believe the NTSB's conclusion was reasonable considering there was no evidence of a YD malfunction. If such evidence surfaces then the probable cause can be corrected.Don't forget, the NTSB also blamed Sten Molin in the A300 NY crash, despite never having affirmed whether the rudder pedals were moved by him or by some yaw damper runaway.
I can't argue with that, however, the big profile crashes do draw the NTSB's maximum efforts and resources. Just keep in mind that their findings are labelled "probable cause" and not "definitive cause". Furthermore lay juries tend to find much more cause than the NTSB.NTSB rulings sometimes must be taken with a grain of salt, and an understanding of human limitations in certain conditions.
I believe the NTSB re-creates scenarios in a simulator and has run-of-the-mill pilots fly the profiles to determine what a reasonable reaction time is.aa73 said:I used this example to compare with the AA727 because of the quick reaction times needed, but not accomplished.
You say the NTSB had no choice but to blame the pilot yet you imply that they did so only because it was expedient. That's contradictory. To the NTSB is looked like the pilot reacted improperly and barring any evidence to the contrary they made their decision. Just like you I'd love to hear that it wasn't the pilot's fault but sometimes it just is.It is much easier to blame a pilot group than a reputable worldwide-known manufacturer. No one knew what caused the rudder to move, so the NTSB has no choice but to blame the pilot flying.
try this. Select the quote a post feature. The next screen you will see is the reply to thread screen. At the top of the message box will be post you chose to quote. Look at that paragraph. You will see the word quote in brackets at both the begining and end of the paragraph. The first time the word quote appears it will be followed by an equal sign and the name of the person who originally wrote it. The quote at the end will be preceeded by a /.aa73 said:Darn I still haven't figured out how to quote in sections! Sorry for the fragmented format.
Maybe it's not coming out the way I meant. I view the NTSB ruling on this crash in the same light as TWA 800. In other words, a cover up.TWA Dude said:You say the NTSB had no choice but to blame the pilot yet you imply that they did so only because it was expedient. That's contradictory. To the NTSB is looked like the pilot reacted improperly and barring any evidence to the contrary they made their decision. Just like you I'd love to hear that it wasn't the pilot's fault but sometimes it just is.
Excellent quoting technique. As far as NTSB cover-ups, well, I guess anything's possible so I can't dispute your claim. But IMHO very few big conspiricies turn out to be true because there's just so many people involved it's hard to keep 'em all quiet. My only objection to the "pilot error" verdict (and I'm sure you'll agree) is that the "contributing factors" often don't get enough air time. Had that A300 been a 767 with a more normal rudder pedal sensitivity even the FO's inputs (assuming that's what they were) wouldn't have likely ripped the tail off. No doubt that'll all be big when the trials come.aa73 said:Maybe it's not coming out the way I meant. I view the NTSB ruling on this crash in the same light as TWA 800. In other words, a cover up.
How do you know what "type" of pilots they were?Good thing they're Nordstrom pilots and not K-mart types...TC
DIA is what locals refer to it as in Denver International Airport. It was also used as an interim code when Stapleton was about to close and DEN was about to open.Hawker rider said:Is the new identifier for the relocated airport at denver KDIA? or is it the iata ident?
I hear more people mention DIA so was just wondering about that... didn't show up in my papers yet..
On C&R it was revealed that it was a SFO based crew.CSY Mon said:How do you know what "type" of pilots they were?
Native AA? Ex-Reno-Air? Ex-TWA? Ex-Eagle?
I'm not sure about the G/S even needing to be pegged because you only have like what, 190' obstacle clearance guarantee on an ILS? Can someone confirm? (sorry too lazy to crack a book right now)AA717driver said:Singlecoil--At most airlines, you have to be stabilized by 500'. Engines spooled up and on the Loc and G/S.
