AA Jamaica UPDATE: Jamaican Investigator claims poor landing
I'm sure Joshua Woods parents find that pretty funny....
Those are fighting words mother f###er!
I am a Southwest Airlines pilot. I think of Joshua Woods much more often than you do. That incident clearly showed braking actions that were less than reported, thrust reversers that were slow to deploy, and two pilots that flew a textbook approach and landing. They were unlucky.
I was trying to give a laugh to those who have been very quick to hurl a dart at Southwest in the past for taxi speeds and our Burbank over-run.
I'm usually a pretty laid back dude but I'd gladly give you a chance to repeat your quip to my face.
Gup
As a ball park figure I see most pilots float about 500 feet for each 5 kts of tailwind (normal flare technique). So assuming they got caught by a 15kt gust component at flare thats about 1500 feet. So if you aim for the 1500 ft mark thats 3000 ft downfield. Thrown in night, rain, and gusts... 4000 ft downfield is not unbelievable to me. I'm sure they recognized they were long and immediately got on the brakes, well beyond auto 3 (which for non-737 guys, behaves like something above normal braking). I suspect the anti-skid kicked in on the wet, rubbery surface towards the end of the runway, and the rest is history. I am only on my second year of carribean flying experience, and I hope to learn from this accident, best of luck to AA and the pilots.
this incident as generated some hangar discussion at my place, as a result, can anyone post the "official" FAA/NTSB/NASA/ALPA/ETC "endorsed" criteria for go-arounds, etc?
I recall you should land on the first third of the runway, however I personally try to physically land on top of the 1000 foot markers, but at 10:40 PM at night I can't dig up any official guidance.
thanks
thanks
http://www.skybrary.aero/bookshelf/books/864.pdf
Good stuff here, too:
http://www.skybrary.aero/bookshelf/books/922.pdf
Gup
It should also be noted that Boeing persuaded the FAA to allow NG737 landing data to include the use of thrust reversers. The accident crew was unaware of this change (As was I and I was a 737 CA at the time) and thought that the reversers would give them an extra margin over their data.
I am all for calling a spade a spade but for my money one of the primary drivers of this accident is that the landing performance data was changed for the NG737 and the crew was not aware.
When the FAA decides to change shjt like this they need to have a big red placard installed on the panel that says "THIS AIRPLANE'S LANDING DATA INCLUDES THE USE OF THRUST REVERSERS UNLIKE EVERY OTHER JET ON THE PLANET!" Instead it was probably a footnote on some B.S. distance learning module.
This is the third time American has been placed on double secret probation for having three incidents or accidents in a row.
I have friends over there and have never believed the B.S. about one group being "the best" but I have always wondered WTF goes on over there.
How much time does the most junior FO have on the job? I mean we (in theory) should be talking about some pretty senior crews up front in AA cockpits.
Little Rock was a senior management pilot plus a new rookie, not the ideal CRM formula.
But today? I doubt that pairing is still happening.
This statement is in no way a comment on the accident in question, but is intended as a review for 737 drivers: To select max autobrakes, you have to pull the knob out as you turn it to the right. For the other selections, you don't have to pull it out. I've seen more than one pilot get confused when you can't turn the knob all the way to max. You have to pull it out first and I don't believe there is a placard for that.
In addition to tailwind flare issues- they probably had a signicant ref + target speed- which means you have to fly the mains to the ground- a normal flare can have you floating for a while.
AA is very much a captain's airline. Unempowered FOs are not good safety wise.
I've already talked about their dependency on automation. It's a number of factors- they ought to address them- but I'm like the poster above- I don't wish trumped up Feds on any airline.
Gup
Textbook?
http://www.ntsb.gov/ntsb/GenPDF.asp?id=DCA06MA009&rpt=fi
Nope!
Guppy. grow a pair!
Gup
Hi Gup:
No offense - but are you really saying that the crew in the BUR incident flew a textbook approach? I , like many here have read the report and I must have missed the comments about a "textbook approach".
I know your earlier comments were meant to get a laugh, and nothing more. But at the end of the day - if your approach is stable by 1000', then 99.999999 percent of the time will result in a normal landing - thats all I am saying.
Metrojet
Most accidents at the majors happen when the PIC is flying.
Probably because a lot of airlines require the captain to land if conditions are not ideal. Making approaches close to minimums or winds beyond a certain limit or special airports make it the captains landing.
satpak77;1932970 Lt. Col. Oscar Derby said:
touchdown usually occurs at 1,500 feet, or between 1,000 and 1,500 feet [down an 8,900-foot airstrip]," Derby said. "Why this aircraft touched down at 4,100 feet is something that we are investigating very carefully in order to determine what the cause might be."
... Lt Derby then nadded, "Monn."
Gup
Guppy,
I wouldn’t get too upset if I were you.
There are still many southwest pilots doing things that can make a landing “unlucky”. By the way, your passengers did not buy a “chance”.
Years after the Southwest Airlines MDW accident I was inbound to MDW and an ILS to 31C with winds out of the southwest and the runway was wet. Numerous Southwest flights were landing on 31C.
My landing data showed the tailwind and wet runway would make landing on 31C unsafe. We alerted approach that we were unable to land on 31C.
Approach immediately said to expect 13C. All the Southwest flights that had been inbound to 31C advised they too could not accept 31C.
Why did all those Southwest flights reject 31C after I refused the runway?
