A few more questions for Netjets drivers
twiddle
Member
I interviewed in early May and just thought of a few things I didn't ask then.
1. Can you use the Blackberry for personal calls?
2. Assuming you supply your own headsets, is there any plane that is too loud for the Telex 750? (Like the EMB-145 I used to fly) Or do people use the Bose.
3. As far as the pay difference for aircraft >40,000 lbs. Is that all Falcon 2000's or just the EX/Easy?
4. What is the difference between an Ultra and an Encore?
Probably just as well you didn't ask that at the interview. :laugh:
Yes, you can. Be smart about it and don't abuse it, but a few minutes here and there to call home is no issue at all. My personal Verizon phone sounds so much better, though, that I don't bother with the Blackberry once I get to the hotel. The BB isn't great as a phone, but it'll suffice when I'm working. (No point in carrying two phones around during the day.)
I used the Telex 750 for my initial training flight in the Excel, and immediately ordered a Bose QuietComfort 2 and a UFlyMike adapter for it. The air noise in the Excel can get very loud, particularly around 300 knots. You'll need to wear earplugs with the 750, then turn the volume up so much that you get a feedback squeal every time you turn your head. It's awful.
Even if I didn't need ANR, I'd want my own headset anyway because I don't really want splatters from somebody else's crew meal sitting 1/2" from my lips. :puke:
Just the EX/Easy, the BBJ, and the large Gulfstreams. Neither of the first two are likely at all for a newhire, and the Gulfstreams are only possible after you've been at NJA for two years. So the up-to-40K payscales are the ones you should look at.
They're the same basic cabin as far as the passengers are concerned. Main differences are that the Encore has a hot wing (versus the Ultra's boots), trailing-link gear for softer landings, and the Honeywell FMZ-2000 FMS that's shared with several of our other aircraft, versus the less-capable GNS-XLS box in the Ultra. The Encore Plus goes a step further, replacing the Honeywell avionics with the Collins Proline 21 system.
1. Can you use the Blackberry for personal calls? Yes, but use good judgement and don't go crazy with it. There is nothing wrong with calling your wife when you get to the hotel.
2. Assuming you supply your own headsets, is there any plane that is too loud for the Telex 750? (Like the EMB-145 I used to fly) Or do people use the Bose. No clue. I've only flown the Ultra and use a Bose. There are guys that use a Telex 750 and do just fine. Personal choice.
3. As far as the pay difference for aircraft >40,000 lbs. Is that all Falcon 2000's or just the EX/Easy? Just the Easy.
4. What is the difference between an Ultra and an Encore? Encore has upgraded engines, trailing link gear, better FMS. From a PAX standpoint, you can't really tell a difference. The Encore+ has the Collins Proline avionics package that is a vast improvement to the Ultra.
Hope that helps.
Question withdrawn due to the fact that I am a moron...and forgot that I asked the same question in another thread but never checked the answer...thanks for answering again though guys!...
I am just curious as to how the flying is divided up. I have heard that some of the fractionals only allow FO's to fly empty legs..and again, NOT to sound petty (because I don't consider myself super pilot or anything), but with my experience, I would consider this slightly insulting.
This exact question was asked recently in another thread. By you, in fact. Did you not see it?
Rather than rehash it, I'll point you to it:
http://forums.flightinfo.com/showthread.php?p=1592764&postcount=10
Hope that helps.
NJA has a minimum time the SIC must have in order to fly pax legs. As soon as that is met I switch legs. SIC can sit in the left seat on ferry legs if the desire hits.
I'm not sure if you knew this but all our pilots are fully typed and qualified in both seats.
CA1900, you are too fast!!!!!
Personally, I don't fly from the left seat all that often. It is a pain to swap stuff over and shift the seats to accommodate my petite frame. :rolleyes: I only swap prior to my training events to re-familiarize myself, but each his/her own.
Encore Plus will be a good fleet. Decent sized fleet, good aircraft, top of the line avionics, and goes everywhere.
Thanks for the quick reply, one more question. Do the long range planes (G200, Citation X etc.) usually only fly the longest legs or is there a good mix of short hops in between?
If you get the X plan on doing a few trans cons. Five hours in a tight cockpit. If you get the 200; I have heard it varies but yes, they do long legs also. I don't think any fleet does just one type of flying, but there are several fleets that don't have the "legs" to do longer hauls. (400, ultra/encore, 800)
I wish I had known this before my IOE tour on the Excel. I tried to use the 750 and it was EXACTLY as described above. Your choice - hear nothing but wind noise or hear but with feedback squeal. Either way your captain and ATC will be equally unimpressed.
I ordered the Bose/UFlyMike and am just finishing my first tour with that setup. I can't recommend it enough.
We fly plenty of short legs in the X. There is almost always a re-po after the trans-con.
This tour I did 4 trans-cons (more or less) in 5 days. 2 coast to coast is a little more normal.
SFO-EWR-TOR
TOR-SFO
SFO-ITH-PNE
PNE-SDL-airline
Day 1 was airline to SDL
SDL-SMO-APC-SFO
Previous tour, the farthest east I went was IAH.
SFO-EWR-TOR
TOR-SFO
SFO-ITH-PNE
PNE-SDL-airline
SDL-SMO-APC-SFO
Shortest leg i ever flew in the X: LGA Rwy 31 to TEB Rwy 19.
Longest... PHOG-SJC or SFO-MVY,
Everything else in between is fair game too.
Mine was LAX 24R to SMO 3 - cleared for the visual just after passing 400ft. Take off to touchdown, less than 4 minutes. Hard to get all those checklists done . . .
How about this
Did this alot at Flexjet.
Dallas Love to Dallas Addison! My record was 3 minutes. I think some have done it in 2!
Damn and i thought cuagoga country to burke lakefront was fast.
yet another NJA questions..
not related to flight duration but..
does anyone know if Netjets require a furlough pilot to resign his seniority number ?
VNY 16R to 1500 feet, left turn to BUR 08. I'm reminded of rear ends and arm joints....;)
Unless NetJets is exactly where you want to be, don't waste our time. We don't want you. Stay at the crappy airline that furloughed you. There are a lot of pilots that consider NetJets their number one destination. Unless its yours as well, stay away.
It is not required.
No, truth is they are not worried about it. If you belong here, you won't want to go back to that rat race anyway.
Encore coast-to-coast
Not sure what plane Capt Dad is in but try this one on for size. It was an actual flight in the Encore. Part 135, FLL - Waco (very quick fuel stop) then on to SAN. Yes, above FL350 so O2 was required and to top it off, a smoker in the back. After that trip still had a ferry to LAS. So, if owner requests a type of plane and want to go coast-to-coast then it shall be. It's all in a day's work.
I can beat that
VNY-GCK-BVY-TEB in an Encore arriving at approximately 4am
or my personal favorite in recent memory
BZN-CYVR-FAR (at 2am to clear customs)- PIT.
Got into PIT at 6am - redeye flying sucks, I don't know how you cargo types do it...
My best in the Encore was SAF-JAX and a ferry from TMB to PWM.
In the Ultra...SEA-GCK-MIA. Good times.
Since you think you are omnipotent, you can guarantee a lifetime of employment with no chance of furlough at netjets right? If so I guess someone wouldn't need to hold onto that fallback card and it would be wise to give it up because you know all and all netjet pilots will be safe from any loss of employment forever. There are never personality conflicts in training and no pilots ever have family conflicts at netjets because you are watching over all. I guess we all can stop using the name of God and just pray to cavpilot.
Relax, it's just an opinion! Keep the number - good for you for getting one. Could really pay off in the future, like you said, you never know! Heck I thought United was the place to be in early 2001. I was kind of bummed I 'only' got hired by NetJets back then . . . now I feel real lucky and help all I can those who want to be here.
